Vehicle speed sensor fault G68
Passi_Fire
Post02-10-2007, 8:52    Subject: Vehicle speed sensor fault G68 Quote
Hi, I'm new here and need some help with a few issues. I drive a 2000 Bora 2.3L 150hp AGZ. I know it's not a diesel, but I know that there are many experts here who are very knowledgeable about cars...
Okay, I used VAGCOM today to read the error codes and check some data.
I made a single mistake.
00281 Ride vehicle. Defect G68 37-00.
Does anyone know exactly what's wrong?
My problem is that when I press the clutch pedal, the engine RPM initially drops below 500 RPM and then stabilizes. Could this be related? I initially thought it might be the clutch pedal switch, but I don't even have one installed.
'To my knowledge, it's not drawing any air leaks, as the issue with the RPM is very sporadic, and sometimes it maintains the RPM perfectly normally.'
'The throttle body has already been cleaned and adjusted, and I don't have a clutch pedal sensor installed from the factory!'
Sure, here's the translation:
'Hello' or 'Greetings'
chris
kane01
Post03-10-2007, 9:04    Subject: Vehicle speed sensor fault G68 Quote
Why don't you try using a speedometer display? If VAG-COM already shows it, it should be possible.
No new posts Zero-tolerance for deviations in the steering angle of th... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zero offset for accelerator pedal angle sensor (G85) in B... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Mass Air Flow Sensor Failure? Diesel Engine Technology
No new posts T4 horn failure Electrical Systems, Vehicle Electronics, Multimedia
No new posts Golf III TDI: Diagnose VA-Defekt Transmission, Chassis, Body & Interior
No new posts 1Z Bug: Interesting Defect Found Diesel Engine Technology
