Keilrippenriemen quietscht! | Posts 16+
Go to page: Previous  1, 2
haehnlein
Post06-02-2003, 19:47    Subject: Quote
Bertil wrote:
Hi Bertil,
actually, yes... I would take the icon_eek.gif tensioner back and keep bothering them until I get a new one. But the warranty should apply to the part itself... of course, it would be more complicated to prove a defect, for example, with a timing belt, but IF the installation of the icon_confused.gif tensioner is as easy as I think, then they are legally obligated to take the part back within 2 years, or am I mistaken?
Best regards, Christian.
haehnlein
Post06-02-2003, 19:59    Subject: Quote
Bertil wrote:
Only with aircraft engines is the maintenance so complex and expensive that you cannot apply the same principles to a car (engine). Or do you expect your workshop to use X-rays to examine the timing belt in order to detect potential damage earlier? icon_biggrin.gif
If the workshops were to do this, I guarantee you an 80% reduction in timing belt failures!
Hi Bertil,
My comparison is, of course, a bit exaggerated... I would already be satisfied with a chain instead of a timing belt. Okay, it stretches, but I don't have a problem with replacing a timing belt or chain -> it's actually fun (but only if you set the timing correctly *whine* *grin*), but rather with the thought that one of my hydraulic lifters might fall into my lap while I'm driving icon_evil.gif. And I'm willing to bet that you can design that stupid torsion spring in the tensioner so that it lasts for the entire life of a car without incurring significant extra costs.
Post06-02-2003, 20:34    Subject: Quote
haehnlein wrote:
....I would take the spanner back and keep bothering them until I get a new one icon_eek.gif But surely the warranty must apply to the item itself....
... that's exactly what I had someone else do...
and the warranty applies to the part.
... IF the installation with the Spanner is as easy as I think, then they are legally obligated to take the part back within 2 years, or am I mistaken icon_confused.gif?
I think the installation is straightforward because I've worked on one before.
By the way, this was before the 24-month warranty period.
that this stupid torsion spring in the tensioner can be designed in such a way that it lasts for the entire life of a car without incurring significant extra costs.
If a cost accountant notices that Supplier B is 3 cents cheaper than Supplier A, the cheaper option is often chosen. Then there's a risk that the quality will suffer significantly.
joergs
Post06-02-2003, 20:49    Subject: Quote
@bertil
'For bean counters, quality doesn't matter. The main thing is that it's cheap, and they can prove that they've saved amount X! Perhaps supplier B will even give the bean counter a 'gift'!'
@all
Okay, on my 1Z model, replacing this spring tensioner is really simple! Just loosen the Allen screw in the middle of the tensioner. This allows you to push the axis with the tensioner towards the air filter box. Then, loosen the two screws on the tensioner. Reinstall in the reverse order. It takes about 1/4 of an hour, that's all!
haehnlein
Post06-02-2003, 21:00    Subject: Quote
joergs wrote:
The bean counters don't care about quality.
All they care about is that it's cheap and that they can prove they've saved amount x!
joergs wrote:
Maybe supplier B will even give the bean counter a "gift"!}
Hi Joerg,
Germany isn't in a bad enough situation yet for the seriousness of the situation to be fully recognized. I read in the FAZ yesterday that 100,000 highly skilled people emigrated abroad last year...probably including those who wouldn't want to continue working with TDI technology. Too bad, actually.
Okay, so on my 1Z, replacing this spring tensioner is very simple! Loosen the Allen screw in the middle of the tensioner element; you can then push the axis with the tensioner towards the air filter box. Loosen the two screws on the tensioner element. Installation is in the reverse order. It takes about 1/4 of an hour! icon_idea.gif
as a hobbyist who likes to tinker, it's something that can be put into practice perfectly.
No new posts Serpentine belt (drive belt) replacement for T6 TDI with ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 Serpentine Belt Tensioner Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T6 TDI, squealing ribbed belt, TPI Diesel Engine Technology
No new posts Timing belt squeaks when it's cold! Diesel Engine Technology
No new posts Squeaky Brake Pedal: Causes and Fixes Transmission, Chassis, Body & Interior
No new posts BMR KRR tensioner squeaks Diesel Engine Technology
