Nachrüst DPF selbst einbauen - Abnahme durch TÜV/Werkstatt? | Posts 16+
Go to page: Previous  1, 2
Post09-10-2007, 8:40    Subject: Quote
So heiß wird es da gar nicht.....Warum es das DIng nicht für den Lupo und Arosa gibt, sollte dir schnell klar werden, wenn du dir Jans Text durchließ. Mangels STückzahlen bedient das der Aftermarket nicht. Zu expensive.
And to be honest, and without wanting to offend anyone too much, I don't think anyone will bother retrofitting a diesel particulate filter (DPF) to an Arosa SDI... there's simply not enough demand for it, in my opinion.
Translated on 01-08-2026, 14:34.
SeatArosa1.7SDI
Post09-10-2007, 16:02    Subject: Quote
My disappointment is limited, should this piece of bad news /viewtopic.php?t=16972 be true.
Regarding the heat: I've been thinking about wrapping the catalytic converter in a layer of rock wool and then carefully covering it with aluminum tape. (I did something similar with the exhaust manifold on my Trabant back then to increase its heating power).
Translated on 01-08-2026, 14:35.
No new posts Doku A3 8L, horn honks by itself Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Engine temporarily maintains RPM, automatically increases... General Tips
No new posts Inspection by authorized workshop or independent garage? Transmission, Chassis, Body & Interior
No new posts Serpentine Belt Squeal: Causes & Fixes Diesel Engine Technology
No new posts Retrofit DPF Diesel Engine Technology
No new posts Retrofit DPF for older R5 TDI (AEL)? Diesel Engine Technology
