VAG 1552 K-line not switching to positive
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Andreas H.
Post01-11-2007, 18:34    Subject: VAG 1552 K-line not switching to positive Quote
When I connect a V.A.G 1552 diagnostic tool to the diagnostic connector of my Volvo V70 VII 2.5L diesel, which is an Audi MSA 15.8 model from the year 2001 and first registered on December 20, 2007, the following message appears:
<V>
After entering "00", the display shows [something].
Vehicle System Test - Q
00-Automatic test run >
Then I press the "Q" key, and the display shows:
<Automatischer>
and then, a short time later...
<Automatischer>
Press "Help", then select "Display cycle".
K-line not grounding.
K-line not switching to positive.
Possible causes:
1. The line is connected to the positive or negative potential.
at mass
Input/output stage defective in the tester.
- Choose your self-test!
Automatic test sequence Help
Then, when the device is connected to the K-line and doesn't switch to positive voltage, pressing "Help" will display possible causes, etc.
I tested the connection cables (V.A.G 1551/3A) for continuity. All 5 wires have a continuous connection and there is no short circuit between them.
Voltage measured while connected to the power supply, using a probe connected to the brown wire.
View of the pin configuration on the VAG1552 connector.
brown + shielding, 9:00 AM.
gray: 0.0V
yellow 12.3V 12:00 PM
green 11.4V
white 10.1V 3:00 AM
Everything is fine, the ignition key is not in the ignition switch.
Does anyone know what's broken, or what I should check or investigate?
Does anyone know the pinout configuration for both sides of the connector?
Andreas
Volvo V70 II
Modelljahr 2001
2,5l 5Zyl. D5252T, 103kW,
ähnlich Motor AEL Audi A6 C4
Stand 04/08 245 000 km
Audi 80 B4 tdi 90PS 1Z
Modelljahr 1993
Stand 04/08 276 000 km
Translated on 15-07-2026, 20:05.
mullemaus
Post01-11-2007, 22:48    Subject: VAG 1552 K-line not switching to positive Quote
If you have an aftermarket radio in your car, try disconnecting it and then trying again icon_wink.gif.
Translated on 15-07-2026, 20:09.
Andreas H.
Post01-11-2007, 23:19    Subject: VAG 1552 K-line not switching to positive Quote
No aftermarket radio installed.
Would simply removing the fuse for the radio be sufficient? That way, I wouldn't have to disassemble all that plastic trim just to get to the radio connectors.
Volvo V70 II
Modelljahr 2001
Modelljahr 1993
No new posts Doku A2 8Z0, Radio schaltet nach Standzeit nicht ein Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Smart Fortwo: Gear won't shift from Neutral to Drive General Tips
No new posts Doku A3 8L bis KW 04/2002, Radio schaltet nicht mehr ein Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Radio schaltet nicht ab On-Board Diagnostics (OBD)
No new posts Automatikgetriebe schaltet nicht Diesel Engine Technology
No new posts The radio won't turn off Electrical Systems, Vehicle Electronics, Multimedia
No new posts Lupo 3L schaltet nicht in 5. Gang Transmission, Chassis, Body & Interior
