Steering Angle Sensor Golf 4: Location & Installation
Jochen_145
Post05-11-2007, 18:38    Subject: Steering Angle Sensor Golf 4: Location & Installation Quote
Hello everyone,
The Golf IV, PQ34 model equipped with ESP, has a steering angle sensor that communicates with the ESP control unit via CAN.
This steering angle sensor needs to be connected to the wiring harness somehow.
Is there a connector or an 'open wiring harness' that is exposed when a PQ 34 vehicle is not equipped with ESP?
If so, where is this connector or this blind cable harness located?
Best regards, Jochen.
Translated on 10-09-2026, 10:24.
mullemaus
Post05-11-2007, 18:56    Subject: Steering Angle Sensor Golf 4: Location & Installation Quote
Is it integrated into the slip ring? icon_wink.gif There are probably also variations in the pin assignments. You should check the wiring diagram. }
Translated on 10-09-2026, 10:25.
Jochen_145
Post05-11-2007, 19:31    Subject: Steering Angle Sensor Golf 4: Location & Installation Quote
Ah, then the CAN (Controller Area Network) must be located on the steering linkage.
That would be enough for me.
Great, thanks.
Jochen.
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: GRA Failure When Turn Signal Is On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Leave the interface permanently connected? On-Board Diagnostics (OBD)
No new posts Audi A4: Gear Selector Display Wiring & Connection Electrical Systems, Vehicle Electronics, Multimedia
No new posts Engine control unit destroyed during start-up On-Board Diagnostics (OBD)
No new posts Engine Power Limiting During Acceleration Diesel Engine Technology
