SDI Injection Pump: First Generation
Kopi
Post07-12-2007, 20:47    Subject: SDI Injection Pump: First Generation Quote
Hello.
Does anyone know the part number for the early SDI 1.9 injection pumps where the gas was still controlled mechanically?
Best regards, Kopi.
Translated on 08-10-2026, 8:12.
Back to top Profile PM Email
Post08-12-2007, 21:22    Subject: SDI Injection Pump: First Generation Quote
SDI has never been available with mechanical throttle.
You probably mean a regular, naturally aspirated diesel engine.
Could you perhaps provide some specifications of the vehicle in which the pump is supposed to be installed?
e.g., a Volkswagen Golf 2 1.6 diesel engine, 54 horsepower.
Translated on 08-10-2026, 8:13.
Kopi
Post09-12-2007, 10:41    Subject: SDI: Digital Video Interface Explained Quote
I believe these pumps were available on the 1996 models with a 1.9L engine and 64 horsepower. They were also used without the needle lift valve, but already with an engine control unit.
Best regards, Kopi.
Translated on 08-10-2026, 8:14.
mdonau
1988 Audi 80
Post09-12-2007, 18:13    Subject: SDI Injection Pump: First Generation Quote
Those were still swirl chamber engines (like the 1Y, for example).
"Pictures or diagrams would be helpful; I'm assuming it's a pump with a LaFB (likely referring to a specific type of fire extinguishing agent)."
SDIs exclusively use VP37.
Best regards, Michael.
Passat 3B AFN Syncro, E46 330D, T3 1,7TDI, T3-Syncro TD
Translated on 08-10-2026, 8:15.
Post09-12-2007, 22:02    Subject: SDI Injection Pump: First Generation Quote
LaFB = Start of support with reduced load.
Or it might have been a model with a theft-deterrent system, which would have had a slightly more powerful motor.
Kopi
Post10-12-2007, 16:30    Subject: Fuel Injection Pump Quote
I asked at a Skoda and VW workshop, and they told me that the first SDI engines had mechanical gas systems.
Best regards, Kopi.
Translated on 08-10-2026, 8:16.
Post10-12-2007, 16:42    Subject: SDI Injection Pump: First Generation Quote
YES?
And "DIE WERKSTATT" (a workshop) asked me if a Golf TDI has an AGR valve.
To summarize again:
- SDIs were developed AFTER TDIs - therefore, they are derived from TDIs.
- All xDI models from Volkswagen (passenger cars) have electronic throttle control and no mechanical linkage.
"We would like the "first SDI" models to be described in more detail, including the year of manufacture and other relevant data."
I can only think of the 1.9 SDI engine in the Golf 3, Polo, and the 1.7 SDI (AKU) engine in the Polo.
(excluding the new 2.0 SDI PD models for now).
If the information comes from a workshop, they might even be able to mention the engine code (if they know what that is, of course).
Translated on 08-10-2026, 8:17.
mdonau
1988 Audi 80
Post10-12-2007, 17:20    Subject: Fuel Injection Pump: Repair & Replacement Quote
Kopi wrote:
I asked at a Skoda and VW workshop, and they told me that the first SDI engines had mechanical GAS.
greeting Kopi
where the "mechanics" are often just parts replacers... and if they can't find an OBD connector, they panic icon_rolleyes.gif.
And yes: I also want to see MKB (presumably referring to a specific component or feature), because then there would be no need for makeshift solutions on the mTDI (presumably referring to a specific device or system).
No offense.
Translated on 08-10-2026, 8:19.
Kopi
Post10-12-2007, 17:53    Subject: SDI Injection Pump: Repair & Replacement Quote
I actually spoke with skilled mechanics, and they told me that the first pumps had a mechanical gas system. At the time, I hadn't asked about the part number, so I thought I'd ask the diesel experts. And now, is the pump not available?
On Gebrauchte Autoteile com, there's a listing with a picture. If you search for "SDI fuel injection pump" on Google, you'll find it. Maybe they've mixed something up.
Best regards, Kopi.
Translated on 08-10-2026, 8:20.
Post11-12-2007, 9:52    Subject: SDI Injection Pump: First Generation Quote
Hi.
If you already have pictures, then please share them.
You have access to all of the following: URL, link, attachment, and the ability to upload files in the upload area.
Translated on 08-10-2026, 8:21.
Post11-12-2007, 10:00    Subject: SDI Injection Pump: First Generation Quote
If you're referring to the AEF:
This is NOT an SDI - it's a swirl chamber direct injection diesel engine, simply an SD.
You can immediately recognize it by the injectors. Specifically, these are nozzle injectors, not hole injectors.
Yes, they had the mechanical adjustment shaft. Just like all Golf 1 D models, Golf 2 D models, and swirl chamber engines in general.
But wasn't the AEF the cheap Lucas fuel injection pump diesel that you can also run on rapeseed oil, but only for about 200 meters before it breaks down?
Translated on 08-10-2026, 8:22.
Gremlin
Avatar-Gremlin
Karma: +91 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post14-12-2007, 11:39    Subject: SDI Injection Pump: First Generation Quote
Okay, so...
"I am also unaware of such a thing; there is no SDI with a mechanical pump! I have been working on a mTDI (or rather, have been working on it for over a year), and it works really well. Now I am preparing a pump from a Fiat Ducato 2.5l DTI (there is also one for the 2.8l engine) – it originally has a 11mm piston inside! icon_lol.gif icon_lol.gif"
Does anyone have experience with this?
Translated on 08-10-2026, 8:23.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts VAG-COM for Ford Galaxy: First Gen Diagnostics On-Board Diagnostics (OBD)
No new posts Haldex 3rd Gen Oil Change Transmission, Chassis, Body & Interior
No new posts No Turbo Lag: First Drive Experience Upload
No new posts Golf 4 Xenon Headlights, Generation 2 Transmission, Chassis, Body & Interior
