Welded Rust Repair: Fixing Longitudinal Beams
Jochen_145
Post05-01-2008, 23:54    Subject: Welded Rust Repair: Fixing Longitudinal Beams Quote
Hello everyone,
The longitudinal member of my relative's Ford Escort doesn't look very good anymore icon_eek.gif.
Due to the lack of cavity sealing, it is 'leaking' from the inside to the outside.
(See image)
How does that work with welding on load-bearing parts?
What should I be aware of?
Can I simply pry out the damaged piece and replace it with a new piece of the appropriate material thickness?
Do I need to spot weld, or can I use seams?
The vehicle must last long enough until it is known again whether CO2 or particulate matter poses the greater problem icon_wink.gif.
So, even longer...
Thank you for your help.
Best regards, Jochen.
 Von Innen nach Aussen druchgerosteter Längstränger im Heckbereich
 File size:  76.55 KB
 Viewed:  6572 times
Translated on 11-09-2026, 9:25.
BM
Avatar-BM
Post06-01-2008, 1:10    Subject: Welded Rust Repair: Fixing Longitudinal Beams Quote
Can I simply pry out the damaged piece and replace it with a new piece of the corresponding material thickness?
Normally, a repair shoe or replacement part would need to be attached using spot welding.
However, since the area is relatively small, I would first cut out only the damaged section at the bottom of the beam, extending up to the side radii, and reconstruct it by welding a 2mm sheet of metal "butt-joint." The sheet metal would initially remain un-welded at the side where there is corrosion. Then, I would repeat the entire process from the side, welding the bottom section, applying filler, sealing it, and finishing the job.
Make sure you don't cut out too much unnecessary information.
3B5 AJM
Translated on 11-09-2026, 9:27.
Post06-01-2008, 2:03    Subject: Welded Rust Repair: Fixing Longitudinal Beams Quote
"On my parents' Opel Omega A, both sills were rusted through in the exact same spot. I removed the loose rust, then welded thick steel plates, about 1 cm thick, over the areas and sealed everything with body adhesive. I passed the technical inspection (TÜV) twice and had no problems for a total of 4 years! The important thing is that the rust holes are sealed. The Omega is now still running in Iran!"
Translated on 11-09-2026, 9:28.
Jochen_145
Post07-01-2008, 12:35    Subject: Welded Rust Repair: Fixing Longitudinal Beams Quote
Thank you very much for your help.
Okay, I'm going to start welding now.
Translated on 11-09-2026, 9:29.
No new posts Boost pressure build-up carrier, AXR Upload
No new posts VAG 2.0 TDI: Longitudinal vs. Transverse Engine Installation Diesel Engine Technology
