luiggi Schrauber
Joined: 02/19/2006 Posts: 392 Karma: +4 / -0 Location: Tirol /Zillertal
10-01-2008, 19:55 Subject: VW Passat 4Motion: AVF Engine Idler Pulley |
"My colleague needs to replace the freewheel pulley on an AVF engine, manufactured in 2002, because the vehicle is making unusual noises when turning and the belt is flapping excessively."
Okay, here's the translation:
"My question is: Can someone briefly explain to me how to proceed? And do I need any special tools, perhaps for dealing with viscosity issues? I understand about needing a multi-tool to change the disc itself, but I'm just unsure about the other things (like the service position, etc.). Thanks."
Translated on 23-08-2026, 19:22.
kuestenkuddel Guest
10-01-2008, 23:45 Subject: Timing Chain Pulley |
Hello Luiggi.
To replace the freewheel pulley, you'll need a tool similar to this one, but instead of a Torx bit, it needs a multi-tooth fitting.
eBay: [310013050277]
Using a wrench or pliers, secure the shaft. Use an adjustable wrench to loosen the pulley (turn it counterclockwise).
First, remove the rib belt, then reinstall it afterward.
Best regards, Kurt.
Translated on 23-08-2026, 19:24.
11-01-2008, 10:43 Subject: VW Passat 4Motion: AVF Engine Idler Pulley |
I've already described everything here in this forum.
But I think Luigi already understood that.
He wanted to know everything about the all-wheel drive system in the 3BG model.
Luiggi - It would be helpful to provide a more readable text or describe in more detail what you want to know.
Okay, please provide the German text you would like me to translate into English. I will only provide the translation. Transparency, Teamwork
Translated on 23-08-2026, 19:25.
Profile PM Garage |
mserge Schrauber
Joined: 06/20/2005 Posts: 923 Karma: +6 / -0 Location: Luxemburg
11-01-2008, 12:47 Subject: Timing Chain Tensioner |
kuestenkuddel wrote: | | With the wrench or clamp, you hold the shaft securely. With the adjustable wrench, you loosen the pulley (counterclockwise). Best regards, Kurt |
"... and if that doesn't work, or if the part is too tight, then you use the impact wrench and you're done in 2 minutes  Then, when you're putting things on, you can get your wrenches." A4 Avant 2,5 tdi 110kw; AFB; BJ2000
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 23-08-2026, 19:26.
kuestenkuddel Guest
12-01-2008, 15:41 Subject: Timing Chain Tensioner |
With the wrench or clamp, you hold the shaft securely. With the adjustable wrench, you loosen the pulley (counterclockwise). Best regards, Kurt.
... and if that doesn't work, or if the part is too tight, then you use the impact wrench and you're done in 2 minutes! Then, when you're putting it on, you can get the wrenches. }
Hi mserge,
What type of nut do you use with the impact driver? And in which direction do you turn it?
Best regards, Kurt.
Translated on 23-08-2026, 19:28.
luiggi Schrauber
13-01-2008, 14:38 Subject: VW Passat 4Motion: AVF Engine Idler Pulley |
Okay, I looked into the engine compartment again, and I'm assuming that I don't necessarily have to put the front of the car in the service position. Otherwise, do I not have a chance to replace the freewheel? Question: What happens if I also want to replace the belt (i.e., in the service position)?
Translated on 23-08-2026, 19:29.
wingmaster Blaumann
Joined: 12/25/2007 Posts: 100 Karma: +4 / -0 Location: Köln
13-01-2008, 21:48 Subject: VW Passat 4Motion: AVF Engine Idler Pulley |
The easiest way is to remove the light machine. That way, you save yourself the trouble of setting up for service and all that other nonsense.
Okay, then I'll use the impact wrench to loosen it and reassemble it. I also use the impact wrench to tighten it; it works perfectly. The freewheel has a standard right-hand thread.
Translated on 23-08-2026, 19:30.
luiggi Schrauber
13-01-2008, 23:33 Subject: VW Passat 4Motion: AVF Engine Idler Pulley |
Thank you for the answers. They were helpful.
Translated on 23-08-2026, 19:31.
mserge Schrauber
14-01-2008, 9:30 Subject: VW Passat 4Motion: AVF Engine Idler Pulley |
... and I borrowed a special wrench from a colleague to get the pulley off. I removed the alternator from its bracket (leaving the cables attached but disconnecting the battery), then rotated the alternator a quarter turn upwards so that my colleague could reach it from above with his impact wrench and "get it done." A4 Avant 2,5 tdi 110kw; AFB; BJ2000
luiggi Schrauber
19-01-2008, 20:15 Subject: VW Passat 4Motion: AVF Engine Idler Pulley |
I finished the whole thing today. I still had to put the front of the car in service mode because I also needed to replace the ribbed belt. The viscous fan was a bit of a problem when removing it because the Allen screw (8mm) was very tight. I made my own wrench to hold it in place. How do you guys hold the disc on the viscous fan? I removed and reattached the freewheel using an impact driver, since I didn't have the special tool that allows tightening with torque control. Everything went perfectly well.
It took me about 4 hours to complete the task.
Translated on 23-08-2026, 19:32.
