Whining during coupling
Marco
Post21-05-2002, 0:02    Subject: Whining during coupling Quote
Hello everyone,
'Recently, my Golf IV has been experiencing an intermittent issue.'
To hear a howling sound when engaging the clutch. It usually occurs when the engine is cold.
It's making a noise and it sounds like metal is grinding against metal.
You often hear it when you're going uphill.
approaches. The clutch seems to be functioning properly.
At least it doesn't slip, and the car only has 57,000 kilometers on it. Where could the error be?
Marco
Translated on 04-07-2026, 21:26.
TL;-)
Post21-05-2002, 8:30    Subject: Whining during coupling Quote
Since the car only has 57,000 kilometers (approximately 35,000 miles), it's probably not very old. Why don't you go to a VW dealership and ask about goodwill options? Perhaps the clutch fluid level is too low?
Best regards, Thorsten.
Translated on 04-07-2026, 21:27.
Post21-05-2002, 10:30    Subject: Hm... what does this mean? Quote
Best regards, thorsten
Marco
Post21-05-2002, 22:40    Subject: Whining during coupling Quote
I'll try that, thank you.
Marco
Michael II
Post22-05-2002, 10:26    Subject: Whining during coupling Quote
If there is oil present in the clutch housing,
The clutch is damaged because it is a dry clutch.
If you're referring to the hydraulic fluid used for the clutch actuation, then a...
The low level was indicated by the brake fluid level sensor, as it is the same reservoir.
Tschüss
Michael II
Translated on 04-07-2026, 21:28.
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil consumption in 2.0 TSI engines: A break-in issue? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Heulen beim Golf 4 TDI Diesel Engine Technology
No new posts Engine Whine: Is It a Turbo Problem? Diesel Engine Technology
No new posts Golf 4 TDI: Strange Noise When Engine Stops Diesel Engine Technology
No new posts Problem beim Ausbau der ESP VP37 beim AEL-Motor (A6 2,5 TDI) Diesel Engine Technology
