Workshop Action: Sharan, Mass Flow Meter Connection (Solution)
Michael II
Post05-03-2003, 10:28    Subject: Workshop Action: Sharan, Mass Flow Meter Connection Quote
Connection for Mass/Longitudinal Beam
Affected Chassis Numbers:
WVW ZZZ 7M Z YV 999 284 - WVW ZZZ 7M Z YV 999 500 7M9 ...
WVW ZZZ 7M Z 1V 000 001 - WVW ZZZ 7M Z 1V 999 432
Cause:
On some Sharan vehicles within the specified chassis number ranges, there is a possibility that the mass cable attached to the front left longitudinal member could come loose. Hereby, this enables
the line to the instrument cluster may be damaged due to the increased transition resistance and the resulting heating.
Solution:
On all affected vehicles, the torque on the ground cable connection to the front, left longitudinal member must be tightened to 20 Nm.
Important:
An active customer notification is not supported.
Tschüss
Michael II
Ratings - Workshop Action: Sharan, Mass Flow Meter Connection
No new posts Workshop action: Free-running disc, Sharan 81kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Pulley Service: Audi A4 66/81 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3: Faulty Fan Repair & Service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AC Leak: Seal to Indoor Unit Failing - Help! Transmission, Chassis, Body & Interior
No new posts Audi 8E Recall: Action 75 B2 Fix Transmission, Chassis, Body & Interior
No new posts Werkstattaktion 40G4 - Traglenker Vierlenker-Vorderachse Transmission, Chassis, Body & Interior
No new posts AGR Seat for VW Sharan 7N Diesel Engine Technology
