OBD 2 Wiring: Route Cables Inside Car
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
kossmann
2016 Audi Q3
Post25-02-2008, 17:51    Subject: OBD 2 Wiring: Route Cables Inside Car Quote
Hello everyone,
Is there anywhere to buy a 2x2 coupler to install a second diagnostic interface inside the car (e.g., in the glove compartment)? Otherwise, it will be very difficult to perform diagnostics while driving new_shocked.gif.
Where would be the best place to tap into the cables? Underneath the fuse box, or is there also a possibility near the glove compartment?
Thank you and best regards!
Post-edit: A "larger" OBD coupling would, of course, be even better – then the adapter from 2x2 to OBD could be eliminated.
Translated on 01-08-2026, 3:25.
Post25-02-2008, 18:04    Subject: OBD 2 Wiring: Route Cables Inside Car Quote
Hi Tino,
It would be simpler to extend an existing 2x2 OBD2 adapter using a quick connector and place the 16-pin connector in the glove compartment.
Or simply get a 16-pin connector and use 3-4 wires.
Translated on 01-08-2026, 3:27.
kossmann
2016 Audi Q3
Post25-02-2008, 18:19    Subject: OBD 2 Wiring: Route Cables Inside Car Quote
I would really hate to cut up the existing adapter. Moreover, with the 2x2 connector plugged in, you can't close the fuse box anymore, and then you might end up with cold feet.
"In-wall socket" might be the right keyword to use on Google - Thank you!
Translated on 01-08-2026, 3:28.
wolfi_b
Post26-02-2008, 10:54    Subject: OBD 2 Wiring: Route Cables Inside Car Quote
Behind the 2x2 connectors, there are screw connections for the K and L wires icon_wink.gif.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3, Quietschgeräusche Kupplung Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 81KW - Kupplung rutscht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbagkontrollleuchte nach Wassermaleur innen Fahrerseite A4 On-Board Diagnostics (OBD)
No new posts Geräusch aus der Gegend des Sicherungskasten ... Diesel Engine Technology
No new posts Clutch Slipping After 20,000 km? Warranty Rights. Diesel Engine Technology
No new posts ASZ and clutch worn out after only 28,000 km? Diesel Engine Technology
