Boost Pressure Intermittent at 1500 mbar
Opferich
Avatar-Opferich
Post24-02-2008, 1:36    Subject: Boost Pressure Intermittent at 1500 mbar Quote
Golf3 Estate MBK ALE 1.9 TDI, 200,000 km.
(AFN Nozzles, MSW, Boost Pressure 1900 mbar)
My Golf has been experiencing boost pressure problems lately. It intermittently only shows 0.5 bar above atmospheric pressure, especially when the engine is warm or after a hot start.
Everything is normal again when the engine is cool.
After unsuccessfully checking the intercooler, mass airflow sensor, N75 valve, and relay 109, the solution suddenly became clear.
In group 10, the ambient pressure is approximately 680 mbar, which is about 300 mbar lower than the pressure sensed by the charge pressure sensor.
At 11 (presumably referring to a temperature or pressure reading), the actual pressure (IST) reaches the target pressure (Soll), but unfortunately, it then reaches 1500 mbar.
Can the Motorola 60-120 kPa sensor be purchased separately, or do I need a new control unit?
Is it possible to simulate a signal using a potentiometer or a resistor?
Translated on 12-10-2026, 15:58.
Opferich
Avatar-Opferich
Post26-02-2008, 11:42    Subject: SEO: Best Practices for Website Optimization Quote
Problem solved, I bought a new control unit.
Thank you for the good advice.
Michael.
Translated on 12-10-2026, 16:00.
No new posts Audi A3 8L, Golf 4 etc. - Turn signal relay is malfunctio... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Light On: VW Transporter T4 Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 8E2 Wiper Problems: Fix Sticking Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1Z Max Pressure 1500 mbar, Control Valve Blocked Diesel Engine Technology
No new posts Boost pressure too high on AWX A4 - Troubleshooting On-Board Diagnostics (OBD)
No new posts Sporadically high loading pressure? On-Board Diagnostics (OBD)
No new posts Intermittent lack of boost pressure, 1.8T AUM Gasoline Engine Technology
