AFN Issues: Troubleshooting and Solutions
Deus Violentia
Post02-03-2008, 11:26    Subject: AFN Issues: Troubleshooting and Solutions Quote
Hello everyone,
"We had a friend install an AFN engine into a Caddy. Now, the problem is that the engine suddenly jerks violently, especially at idle. The rev counter on the Golf 3 dashboard is erratic, showing fluctuations of up to 300 RPM. However, the engine doesn't shake as much as you would expect from a 300 RPM difference. It runs smoother above 3000 RPM."
The ignition timing is sometimes more than 2.5 degrees advanced, but the control unit is injecting zero correction. Oh, and the power seems to be fully there, at least as far as I can tell, if it's running up to the 4th cylinder.
No error codes found in the control unit.
What I can rule out, as it has already been checked or replaced by us:
- Fuel injectors - brand new ones have been installed.
- LMM - shows values within the normal range.
- Fuel injection pump - replaced, but the same problem persists.
- Needle lifter - replaced, but the same problem persists.
- Timing is correct.
- Pistons in good condition, as they are only 200km old.
- Diesel filter is in like-new condition and has been drained.
- Timing belt in good condition, only 200km old.
- Relay 109 is activated.
- Valve for injection start --> see pump.
Not yet checked, or I don't know how to check it.
- Speed sensor (where is the sensor ring located, could it come loose?)
- ZMS (Could such an error occur if it breaks?)
- AGR
- Turbocharger
I'm at a loss, what can I do? icon_surprised.gif icon_surprised.gif icon_surprised.gif
Translated on 16-10-2026, 13:50.
Post06-03-2008, 14:20    Subject: AFN Issues: Troubleshooting and Solutions Quote
Deus Violentia wrote:
The ignition timing is partially more than 2.5 degrees advanced, however, the control unit 0 injects a correction amount
of
ignition timing? What a terrible mistake in the diesel reservoir!
Which specific sizes (MWB) are you referring to?
..... Oh, the performance is definitely there, or at least that's what I would say, if it goes up to the 4th winding
...... }What does "wickeln" mean?
If the MSG (Main System Board) is damaged, I would first install an original replacement.
Translated on 16-10-2026, 13:53.
Jochen_145
Post06-03-2008, 15:37    Subject: AFN Issues: Troubleshooting and Solutions Quote
Is it perhaps the engine from your other thread?
Then the problem would be due to the incorrect injection amount from the oversized pump, which is not properly adjusted in the engine control unit (ECU).
The actual fuel injection amounts are significantly higher than what the engine control unit (ECU) believes they are, leading to excessive fuel being injected and causing jerking or hesitation.
Do you currently have multiple 'projects' or 'challenges' on your plate?
Best regards, Jochen.
Translated on 16-10-2026, 13:55.
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Causes of the shaking, Engine is shaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ölverbrauch AFN 1l/1000km mit PÖL *ratlos* Diesel Engine Technology
No new posts 1Z Engine Starting Problems - Workshop Stumped? Diesel Engine Technology
No new posts Car Repair: Mechanic Can't Find the Problem? Transmission, Chassis, Body & Interior
No new posts Help with error 575, I'm at a loss and have read through ... On-Board Diagnostics (OBD)
