Difference in fuel injection pump AFN
vrschrauber
Post07-03-2008, 23:44    Subject: Difference in fuel injection pump AFN Quote
Hello!
What is the difference between VEP 028130115A (for Golf III, Passat, A4, etc.) and VEP 028130115B (for Sharan)? Does the 028130115A also fit in the Sharan, or are there any issues with it?
screw installer
Boro
Post09-03-2008, 23:09    Subject: Difference in fuel injection pump AFN Quote
'A' has an 8-pin + 3-pin connector, while 'B' from the Sharan has a 10-pin connector! Mechanically, they are the same, as far as I know! I also successfully used a B pump after modifying the connector.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts Unterschied 2.0 TDI CR 143 vs 120 PS Diesel Engine Technology
No new posts V6 TDI: Differences between engine codes AFB and AKN Diesel Engine Technology
No new posts Unterschied ALH und AFN die 2. Diesel Engine Technology
This topic is locked, you cannot edit or reply. Unterschied TDI und TD? Diesel Engine Technology
