Doku Golf 1J, Manual transmission, Difficult to shift gears (Solution)
Michael II
Post06-03-2003, 16:37    Subject: Doku Golf 1J, Manual transmission, Difficult to shift gears Quote
Gearbox 02J/02C
Rope jumper, transmission difficult/hard to shift
Cause:
The shift lever pivot sleeve in the gearbox has torn at the spline (fine hairline crack) and is misaligned on the shift lever.
Solution:
Disconnect the external gear shift lever.
Gear shift lever with the hand, in the direction of reverse gear, (vertically downwards). Here, the shift lever should move smoothly, meaning it should be able to be pushed down without any noticeable resistance.
Is this not possible:
Remove the gear shift shaft and inspect the locking sleeve for damage (cracks). Possible: Part replacement/Gear control cable.
Warning: The gearbox control shaft must always be slightly {FREE}.
Let the crankshaft out of the housing!
Tschüss
Michael II
Ratings - Doku Golf 1J, Manual transmission, Difficult to shift gears
No new posts Golf 1J: Gearbox Problems & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Gearbox 02K: 3rd Gear Hard to Shift Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A2 8Z0044 AMF, Difficult to shift reverse gear Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4: How to Enable/Disable ABS? On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Golf 6: Heavy Steering - Causes & Fixes Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
No new posts Golf II TD transmission Diesel Engine Technology
