Document Golf 1J1587, Transmission Console Mounting Not Releasing (Solution)
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post07-03-2003, 11:05    Subject: Document Golf 1J1587, Transmission Console Mounting Not Releasing Quote
Do not loosen the transmission console mounting.
(The gearbox console fitting cannot be detached, a screw broke off during repair.)
Cause:
Thermally induced hardening of microencapsulation/fastening screws, console attached to the transmission housing (modified fastening method introduced in series production since 06/98).
Solution:
Repair or, if necessary, replacement of the fastening screws, part number N 104 062.02 (M10 x 80 - microencapsulated).
Screws that are difficult or impossible to remove due to micro-encapsulated adhesive (blue color) can be more easily loosened when the equipment is operating at its normal temperature (approximately 80°C) or by heating the screws with a hot air gun (approximately 80°C).
TschĂŒss
Michael II
Ratings - Document Golf 1J1587, Transmission Console Mounting Not Releasing
No new posts Golf 1J1587: Haldex Control Unit Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, from 5/99, Rear door lock not working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Window doesn't close Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 7 exterior mirror glass is coming loose Transmission, Chassis, Body & Interior
No new posts QL Mount Motherboard: Secure & Easy Installation Transmission, Chassis, Body & Interior
No new posts VNT15 Turbo Installation on AFN Engine Diesel Engine Technology
No new posts Loosen Triangle Screw on ESP Guitar Diesel Engine Technology
