A6 AFB Engine: Hard Brake? Troubleshooting.
luiggi
Post12-04-2008, 16:21    Subject: A6 AFB Engine: Hard Brake? Troubleshooting. Quote
I just drove my brother's car, as he claims that the brakes are very stiff and have relatively little brake assist.
I've also noticed this myself. Normally, when you press the pedal, it should give way slightly, and then the brakes should engage firmly without requiring much force.
From the beginning, these vehicles require more force to operate, and the pedal feels very stiff.
Could it be that the vacuum pump, which is mounted on the left cylinder head, is not providing enough power? The engine doesn't have a noticeable drop in power during slow acceleration, but when accelerating quickly, there's a slight surge around 3000 RPM, and the vehicle feels more responsive. I'm asking because the vacuum system is also related to the turbocharger pressure regulation. Perhaps this slight loss of power and the hard braking could be resolved by replacing the vacuum pump.
By the way: Has anyone ever had the vacuum pump fail on a V6-TDI engine? Best regards[/i]
Translated on 07-09-2026, 1:11.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post12-04-2008, 18:02    Subject: A6 AFB Engine: Hard Brake? Troubleshooting. Quote
I don't think the vacuum pump is going to be okay.
More likely, it's the vacuum hose for the BKV (boost control valve).
This is a typical Audi problem.
That would also explain the increase in thrust at 3000 rpm, as the thrust increases with increasing...
The speed and suction power of the vacuum pump increase.
Translated on 07-09-2026, 1:13.
bloesch
Post12-04-2008, 20:01    Subject: A6 AFB Engine: Hard Brake? Troubleshooting. Quote
alternative option:
Many models from the Volkswagen Group suffer from clogged water drainage channels in the expansion tank.
I've seen a few cases where people had to stay somewhere, and in some of those situations, the internal components of the BKV (presumably a piece of equipment) rusted.
Translated on 07-09-2026, 1:14.
Tagessuppe
Post12-04-2008, 20:59    Subject: A6 AFB Engine: Hard Brake? Troubleshooting. Quote
I also thought that might be the case at the beginning.
Did I also experience the BKV (presumably a device or system) failing suddenly in my A3?
However, after that, the car was practically undrivable and impossible to brake, to the point that...
It almost felt criminal. At least the Poroesem hose has some brake reinforcement.
Translated on 07-09-2026, 1:15.
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts Electric Brake (EPB) Diagnosis and Maintenance Troubleshooting & Guides
No new posts Document Passat, Model Year 2000, Brakes Stuck Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts The engine is very loud at RPMs above 3800. Diesel Engine Technology
No new posts Golf IV TDI starts poorly when the engine is warm - DKE i... Diesel Engine Technology
No new posts TDI Engine Problems: 1.2L 3-Cylinder Runs Rough Diesel Engine Technology
No new posts Parking Heater Smoking: Troubleshooting & Fixes Transmission, Chassis, Body & Interior
