Skoda Symphony/VW Rhapsody Upgrade Adapter
Wiesel
Post06-05-2008, 10:18    Subject: Skoda Symphony/VW Rhapsody Upgrade Adapter Quote
I assume that the hooks go into the slots marked with arrows.
The (actually) current unlocking mechanisms for the horizontal slots (bottom left) do not fit.
(even though almost all searches lead to these parts).
The older ones (designed for vertical slots), which were used, for example, in G3 radios.
They don't fit either.
Does anyone have a picture/link/part number for the correct hooks?
Okay, here's the translation:
Thank you.
"Micha"
 File size:  140.9 KB
 Viewed:  16789 times
Translated on 31-10-2026, 2:22.
tdi-schrauber
Post11-05-2008, 18:16    Subject: Skoda Symphony/VW Rhapsody Upgrade Adapter Quote
Hello!
If necessary, a metal saw blade with the teeth removed will suffice.
Or a large, flat pizza base, or a sheet of dough...
The main thing is that it fits.
Insert approximately 2cm and push outwards. Then, remove the radio.
BYE
TDI mechanic.
Translated on 31-10-2026, 2:24.
Wiesel
Post11-05-2008, 20:21    Subject: Skoda Symphony/VW Rhapsody Upgrade Adapter Quote
I had already made some progress in the meantime.
The original part number for the hooks is T30005, and they cost approximately 20€.
I recreated the parts using stainless steel sheet metal strips - they work great.
When I have the chance, I'll create a drawing and post it here.
Best regards, Micha.
Translated on 31-10-2026, 2:25.
Wiesel
Post14-05-2008, 14:32    Subject: Skoda Symphony/VW Rhapsody Upgrade Adapter Quote
Okay, here is the "homebrew" T30005 icon_mrgreen.gif.
The material I'm using is 1mm thick stainless steel sheet. The elongated hole was created by drilling two 2mm holes.
that were associated with a key file and had a notch at the tip.
I also did it with a round file.
Instead of using rivets, I simply left the metal pieces a bit longer and extended them to the sides.
bent over.
 File size:  24.13 KB
 Viewed:  12061 times
Translated on 31-10-2026, 2:26.
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Broken sun visor clip for Audi, Seat, Skoda, VW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Superb Estate (Wagon), 2012, Tailgate Actuator Defe... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Radio Symphony in Golf 3 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Skoda Daytime Running Lights: Best Options Transmission, Chassis, Body & Interior
No new posts DK Skoda Fabia 1.4L 16V Gasoline Engine Technology
No new posts Skoda Octavia 1.9: Specs, Problems, & More On-Board Diagnostics (OBD)
