Zweimassenschwungrad BPX gibt es einen umbaukit auf Einmasse | Posts 32+
Go to page: Previous  1, 2, 3
Jens 16syncro
Karma: +2 / -3   Thank you, like it!
Post14-05-2008, 8:13    Subject: Quote
Thomas wrote:
There's a program where you can look up all the parts from VW, etc. ...
Hi Thomas,
I checked the specifications for the Onkel 7 (manufactured in 2007) yesterday, and it's true, it doesn't have a 2.0-liter 4-cylinder engine. Among industrial engines, you'll only find the 1.9L engine with VEP (Variable Emission Process) and a very old 2.0L 5-cylinder industrial engine (swirl chamber).
The 1.9L VEP engines have a fixed 228mm flywheel listed, while the 5-cylinder engine (MKB: 068)) has none at all. To the best of my knowledge, the Wiesel 1 air-portable tank is equipped with an automatic transmission and a different engine.
Jens.
Thomas
Post14-05-2008, 22:05    Subject: Quote
Hi Jens,
You're right! Now that you mention it, I once read a Motorwelt article about the PD engine in the Wiesel. Just so that he probably still has some protective measures against shelling there. icon_smile.gif But do you happen to have a manual for that engine?
However, I am also confident that the "next generation" of industrial engines will be pump-injector or common rail systems. You should take a look at the current catalog.
Thomas.
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
Jens 16syncro
Post15-05-2008, 8:55    Subject: Quote
The Wiesel 1 is equipped with a 2.0-liter, 5-cylinder swirl chamber diesel engine, model code: 068.
The Wiesel 2 was then equipped with the 1.9L VEP-TDI engine, which is essentially the counterpart to the 1Z engine.
I don't know the exact engine code (MKB) right now, but all the information is available in the VW program, Uncle7. Currently, the 63kW version of the 1.9-liter VEP-TDI engine has the MKB code AFD, but that's already the new engine block without the intermediate shaft. In the Wiesel 2, the old 827 engine casing might still be installed.
Currently, both versions are available as industrial engines at VW: the 1.9-liter VEP-TDI and the 2.0-liter PD-TDI. CR isn't available yet, but that will definitely be coming soon.
Jens.
Frank A.
2000 Volkswagen Golf
Post15-05-2008, 9:18    Subject: Quote
Hello Thomas,
The model codes for the new PD industrial motors are, for example, CBHA and CBJB.
The flywheel is still listed as 026105269L, which was also used in the older versions.
"It was equipped with an industrial engine."
'00 G4 ALH 170tkm , 11mm Pumpe, GGU-Getriebe
No new posts Passat gibt Schläge - ESP Leuchte geht an Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine temporarily maintains RPM, automatically increases... General Tips
No new posts Calix Motor Heater Installation Guide Troubleshooting & Guides
No new posts Two-mass flywheel?! Diesel Engine Technology
No new posts Two-Mass Flywheel Error Images Diesel Engine Technology
No new posts Defective Dual Mass Flywheel: Symptoms & Repair Diesel Engine Technology
No new posts Two-mass flywheel end of life Transmission, Chassis, Body & Interior
