Knistern under Defrost-Ausströmer beim Passat 3C
Post04-02-2008, 22:10    Subject: Knistern under Defrost-Ausströmer beim Passat 3C Quote
My Trekker is driving me crazy.
My icon_smile.gif is very diligent in trying to teach the dog proper manners, but the interior keeps inventing new things.
Currently, it's somewhere under the defrost vents - that is, the grille that ventilates the windshield.
The icon_smile.gif has already installed the that was attached to the control panel, but NOT the individual that was not available separately - but I was quite sure about that.
Normally, you drive for about 5 minutes, and then each suspension wave (in combination with the Sportline suspension) makes a "knack" sound. If it gets really bad, even the otherwise very refined engine can produce a "knrnrnrnrnrnrnrnks" sound.
It sounds like a Climatronic button that is either opening or has some play in its mechanism.
Has anyone experienced similar occurrences or, specifically, heard anything related to 3C before?
Thank you.
Post06-02-2008, 20:48    Subject: Knistern under Defrost-Ausströmer beim Passat 3C Quote
Right there, where it snaps, is one of the clips 8E0 857 117.
Does anyone have a picture of a 3C WITHOUT a control panel?
Then I could better visualize the internal workings and work more effectively.
Radio and the glove compartment were already outside, when I upgraded the footwell lights.
Thank you.
vagtuning
Post06-02-2008, 22:49    Subject: Knistern under Defrost-Ausströmer beim Passat 3C Quote
Poor quality, but maybe something meaningful can be found?
 3C
 File size:  75.63 KB
 Viewed:  9611 times
Post07-02-2008, 9:54    Subject: Knistern under Defrost-Ausströmer beim Passat 3C Quote
Thank you very much.
(Very similar to me: Climatronic, latte macchiato on cloth, manual transmission icon_wink.gif )
Unfortunately, the exact "problem area" is not very clear.
Do you have any more pictures?
 File size:  127.03 KB
 Viewed:  5620 times
Post07-02-2008, 10:14    Subject: Knistern under Defrost-Ausströmer beim Passat 3C Quote
Here is a wanted photo of the currently suspected individual (number 2):
 File size:  154.15 KB
 Viewed:  5083 times
vagtuning
Post07-02-2008, 13:11    Subject: Knistern under Defrost-Ausströmer beim Passat 3C Quote
Unfortunately, nothing more found, sorry.
Post13-02-2008, 21:27    Subject: Knistern under Defrost-Ausströmer beim Passat 3C Quote
Who knows how these brackets are installed?
So, which claws reach where in?
 File size:  135.45 KB
 Viewed:  4934 times
 File size:  136.99 KB
 Viewed:  4937 times
Post18-02-2008, 9:29    Subject: Knistern under Defrost-Ausströmer beim Passat 3C Quote
This thing is driving me crazy.
Now I've managed to wedge a piece of material between the disc and the control panel, and the rattling has stopped.
Now, with strong ground irregularities, it "knacks" to the LEFT! (but only much, much less often and slightly quieter). Nevertheless, you can sometimes simulate it by hitting the gear lever.
 File size:  196.96 KB
 Viewed:  5015 times
Post18-02-2008, 16:50    Subject: Knistern under Defrost-Ausströmer beim Passat 3C Quote
Okay.
Now I know what "it" looks like "down there".
So, es kann eigentlich nur die Klammer in der Karosse sein, oder?
 File size:  82.73 KB
 Viewed:  4790 times
Post19-05-2008, 13:34    Subject: Knistern under Defrost-Ausströmer beim Passat 3C Quote
Okay,
New theory:
Maybe it's the airbag bracket frame, which is secured to the dashboard with self-locking nuts.
The airbag can be removed with the built-in dashboard... this is the next step.
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A2 Document: Tapping Noises Below 1600 RPM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3bg 1.9 TDI PD / Brake, front left, under pressure Transmission, Chassis, Body & Interior
No new posts Passat 3B: Excessive Smoke Under Load - Troubleshooting Diesel Engine Technology
No new posts Noise from belt drive and crackling near the alternator Diesel Engine Technology
No new posts Passat TDI: Diagnosebuchse - Standort & Anleitung Diesel Engine Technology
