VP44: Seal & Disassemble - Repair Guide
dokatoto
Post02-06-2008, 8:25    Subject: VP44: Seal & Disassemble - Repair Guide Quote
Can the VP44 be disassembled and resealed as 'easily' as the often-described VP37?
Do they offer any sealing kits compatible with biodiesel at Bosch, or are those only available for trucks now?
The logistics companies I know all use biodiesel, and they all have Bosch pumps in their vehicles, which is strange because it seems to work so well.
Thank you and best regards.
Toto.
Translated on 04-09-2026, 17:23.
bastion
Karma: +6 / -1   Thank you, like it!
Post02-06-2008, 20:15    Subject: VP44: Sealing and Disassembly Guide Quote
And that's precisely the main reason why it works: they only use biodiesel.
Biodiesel only causes fuel pumps to leak when a mixture of biodiesel and regular diesel is used. It's not uncommon for a fuel pump to leak with regular diesel but seal properly with biodiesel. This is because biodiesel can cause brittle seals to swell again (after it has initially caused them to leak by washing out the plasticizers).
A4 Avant 08/01 AWX 05/08-
Translated on 04-09-2026, 17:24.
No new posts Disassembling the metering unit of a VP37 Troubleshooting & Guides
No new posts Bosch VP44 pump control unit repair Troubleshooting & Guides
No new posts VE Injection Pump Data: 6-Cylinder Engine Performance (VP44) Technical Data
This topic is locked, you cannot edit or reply. Sealing the MSW (Motor-Schwingung-Welle) of a VP37 engine... Diesel Engine Technology
No new posts Cost for sealing PDEs Diesel Engine Technology
No new posts Windshield washer pump leaking: Tips for sealing it? Transmission, Chassis, Body & Interior
No new posts VP44 control unit replacement On-Board Diagnostics (OBD)
