Quote: |
| I drive a new Fiat Bravo 1.9 Multijet 16V. When pressing the clutch pedal while stationary, the engine noise gets louder. Subjectively, it sounds like knocking, which disappears when the clutch is fully engaged. While engaging the clutch during driving, you can hear a slight "rumbling" as the engine speed drops. The pedal is easy to press, and the clutch engagement is very smooth. |
If this Fiat still has a clutch cable, it is possible that the noise could be transmitted from the cable to the pedal assembly if the cable is under tension. In that case, it would be considered normal.
