Secure ZR Bolts with Loctite: Best Practices
bernie123
Post10-06-2008, 23:12    Subject: Secure ZR Bolts with Loctite: Best Practices Quote
Hello forum,
empfiehlt sich die o. g. Aktion, also die Muttern und Schrauben die im Spannbereich d. ZR
Is it possible to secure it with Loctite?
"asks"
bernie
Translated on 12-10-2026, 10:05.
BM
Avatar-BM
Post10-06-2008, 23:47    Subject: Secure ZR Bolts with Loctite: Best Practices Quote
to be located, secured with Loct***?
It's something you can do, but you don't necessarily have to. It's more important to use the correct torque settings for the bolts. If it's a VAG diesel engine, you should replace the tensioner stud and follow the tensioning instructions. There are some rollers where the entire tensioning process needs to be repeated if the roller is tightened too much.
3B5 AJM
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Serpentine belt (drive belt) replacement for T6 TDI with ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ATF (Automatic Transmission Fluid) replacement in the aut... Troubleshooting & Guides
No new posts Torque Specs: G4 Variant Roof Rail Nuts Transmission, Chassis, Body & Interior
No new posts How to reset the service indicator on an Audi A3? Diesel Engine Technology
No new posts Grinding Noise When Starting? Get Help Now! Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. OEL Dashboard Light: What Does It Mean? Diesel Engine Technology
