Water in Sharan Brake Cable - Model '99
sophiea47
Post07-02-2003, 10:50    Subject: Water in Sharan Brake Cable - Model '99 Quote
As soon as the outside temperatures drop below freezing, the handbrake on my Sharan (built in 1999) freezes solid. The rear brake cables no longer release. I took one out and put it in the freezer. Afterwards, it was completely stuck. How does water get in there? What can be done about it? Has anyone else experienced similar problems?
Translated on 16-08-2026, 18:03.
christians
Post16-02-2003, 20:33    Subject: Water in Sharan Brake Cable - Model '99 Quote
It doesn't seem like it was a very interesting topic.
I've experienced the same problem myself. It also occurs with various vehicles belonging to my employer.
Cause: Splashing water, undercarriage wash.
Suggestion: Either buy new ones or dry them in the oven at 50-70°C. Afterwards, grease them thoroughly, making sure the fat penetrates deep into the casings.
Gruß Christian
Translated on 16-08-2026, 18:04.
Post17-02-2003, 9:22    Subject: Rubber Seals: Types & Applications Quote
Do your handbrake cables have rubber grommets where the cable exits the housing?
Translated on 16-08-2026, 18:05.
christians
Post17-02-2003, 12:54    Subject: Water in Sharan Brake Cable - Model '99 Quote
Mine has those rubber parts. It's also clear that, due to their age, they have deteriorated somewhat on my car. But for a vehicle manufactured in 1999?
Gruß Christian
Translated on 16-08-2026, 18:06.
Mc_Givertechnik
2010 Volkswagen T5
Post19-03-2003, 13:36    Subject: Water in Sharan Brake Cable - Model '99 Quote
If there's even the smallest crack in the casing, that's enough. I've seen this problem before in many cars. A highway drive in heavy rain is all it takes for water to accumulate in the handbrake cable.
Greetings,
Peter.
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
No new posts Handwashing on the go, without water General Tips
No new posts Doku Polo 9N, water accumulates in the footwell during he... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB ANU Engine Noises: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sharan: Water Leak from Rear Window Washer System Transmission, Chassis, Body & Interior
No new posts Parking Brake Cable Housing Transmission, Chassis, Body & Interior
No new posts Water in the lock... Transmission, Chassis, Body & Interior
No new posts Passat 3B: Oil in Coolant - Causes & Fixes Diesel Engine Technology
