Golf 4 TDI Engine Mounts: Replacement & Repair
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post09-05-2008, 18:39    Subject: Golf 4 TDI Engine Mounts: Replacement & Repair Quote
Hi.
"I've noticed a strange clicking sound coming from the engine compartment for the past few days. It usually happens when I quickly accelerate, or when I rapidly press and release the gas pedal, and often when shifting gears."
I suspect that an engine mount is broken. Has anyone else experienced something like this with a Golf 4 before? If so, which mount is usually the problem? I'm guessing it's probably the rear one, number 3.
"MFG" is an abbreviation for "mit freundlichen Grüßen," which means "best regards" or "sincerely." It is commonly used in German-language emails and letters.
Audi SQ5 8R Cvub
Translated on 15-10-2026, 6:38.
Back to top Profile PM Email
Karma: +645 / -0   Thank you, like it!
Post12-05-2008, 16:10    Subject: Golf 4 TDI Engine Mounts: Replacement & Repair Quote
Hi.
Have an assistant engage the parking brake and slowly move the vehicle forward and backward while you check the engine mounts.
Best regards, Rüdi.
P.S. Alternatively, one could consult the crystal ball icon_cool.gif.
Translated on 15-10-2026, 6:39.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post12-05-2008, 17:38    Subject: Golf 4 TDI Engine Mounts: Replacement & Repair Quote
Or simply order all 3 from me - icon_lol.gif.
No, like above: or, grab the bull by the head and move it, and you'll see where it gives way.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 15-10-2026, 6:40.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post20-05-2008, 15:54    Subject: Golf 4 TDI Engine Mounts: Replacement & Repair Quote
I've experienced that before too. Interestingly, the exhaust seems to also have a motor-dampening function.
"The brackets that hold the catalytic converter in place were broken on my car, and when I was driving, the engine was shaking terribly."
Of course, also make sure that the motor mount is securely fastened in the center.
However, they rarely wear out. And if they do, you can disassemble them and replace the rubber insert separately.
Translated on 15-10-2026, 6:41.
pa-mm6
Post26-06-2008, 20:07    Subject: Golf 4 TDI Engine Mounts: Replacement & Repair Quote
Hi.
"Today, I noticed that my inner CV boot is torn. I suspect that the CV joint might be defective, although that shouldn't normally cause a cracking sound. It should make a noise immediately when the wheel is turning. I'm really starting to get frustrated. Strangely, the cracking sound is very noticeable when it's very hot outside."
Audi SQ5 8R Cvub
Translated on 15-10-2026, 6:42.
a dancer
Post26-06-2008, 20:23    Subject: Golf 4 TDI Engine Mounts: Replacement & Repair Quote
Perhaps it's the suspension of the wheel hubs.
On my Ibiza, a strut broke after 100,000 km, specifically the rear rubber bushing of the suspension arm.
It had 10mm of play, and it was rubbing rubber against steel.
I noticed it because of a squeaking sound when the load changed.
With another 20,000 kilometers, the pressed-in bushing would have worn through, and then steel would have been rubbing against aluminum.
Translated on 15-10-2026, 6:43.
No new posts Tankklappenentriegelung failure Golf 5 Variant Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Interior lighting / door lights defective (for Golf IV / ... General Tips
No new posts Golf 5 Radio Volume Problem - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Flexible pipe broken again! Should all engine mounts be r... Transmission, Chassis, Body & Interior
No new posts Golf I power steering failure??? Diesel Engine Technology
No new posts Golf 4 Clutch Slave Cylinder Replacement Transmission, Chassis, Body & Interior
No new posts Wheel Bearing Problems VW Golf 6? Transmission, Chassis, Body & Interior
