Document Transporter 7D, vacuum pump making noise (Solution)
Michael II
Post20-03-2003, 11:15    Subject: Document Transporter 7D, vacuum pump making noise Quote
Vacuum pump is making noise.
Cause:
Improper installation of the vacuum pump plunger can cause noise or damage to the vacuum pump.
Solution:
When replacing the vacuum pump, it is essential to ensure that the correct plunger is used.
AAB engine up to chassis number 70R - 180,000.
Vacuum pump: No. 075 145 100.
Piston: No. 075 145 307 with a length of 71.0 mm.
AAB engine, from chassis number 70R - 180,000.
Vacuum pump: No. 074 145 100 A
Piston: No. 074 145 307 with a length of 67.5 mm.
ACV, AJA, AHY, AHD, and AGX.
Vacuum pump: No. 074 145 100 A.
Tschüss
Michael II
Translated on 20-07-2026, 14:01.
Ratings - Document Transporter 7D, vacuum pump making noise
No new posts Doku Caddy 9K: Drum Brake Noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Air conditioning compressor making noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Starter Motor Noise: VW Golf 4 & Similar Troubleshooting & Guides
No new posts TDI Belt Drive Noise: Causes & Solutions Diesel Engine Technology
No new posts Climate compressor making noise Transmission, Chassis, Body & Interior
No new posts Climatronic Blower Motor Noise: Troubleshooting Guide Transmission, Chassis, Body & Interior
No new posts Vacuum Pump 1Z Disassembly Guide Diesel Engine Technology
