Doku Caddy 9K, from KW26/97, Loud Noise (Solution)
Michael II
Post20-03-2003, 15:51    Subject: Doku Caddy 9K, from KW26/97, Loud Noise Quote
Grinding noise at the rear axle
Cause:
Water ingress through the wave seal ring into the wheel bearing leads to corrosion and damage/destruction of the bearings.
Solution:
In case of complaints, the entire axle bearing must be replaced. For this purpose, part number 6K9 598 625 is available.
Before installing the brake drum, the new crankshaft seal must be greased (Grease: No. G 052 735 A2) to be filled.
Additionally, a small amount of grease (approximately 3 to 4 mm) should be applied around the sealing lip, which rests on the crankshaft flange.
Tschüss
Michael II
Ratings - Doku Caddy 9K, from KW26/97, Loud Noise
No new posts Doku Caddy 9K Rear Axle Noise (1998) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K9, MKB AGP, Increased oil consumption Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K: Drum Brake Noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Caddy 9k9: Rattling Noise - Diagnosis & Repair Diesel Engine Technology
No new posts Caddy Life On-Board Diagnostics (OBD)
No new posts Caddy interior lights On-Board Diagnostics (OBD)
No new posts Caddy Trailer: Buy, Sale & Accessories On-Board Diagnostics (OBD)
