TDI-Daniel Blaumann
Joined: 08/29/2007 Posts: 78 Karma: +1 / -2 Location: Wilnsdorf
16-07-2008, 21:31 Subject: |
Yes, that might be the case. Do you have a new LDA?
I have a private message for you. Audi A6 Avant 4B 2,5l TDI AKE
Audi S6 Avant C4 4,2l AEC
Golf 4 AKL Benzinfresser
Translated on 14-10-2026, 5:14.
Profile PM Email |
paddy84
1996 Volkswagen Golf Free account, no CAN development support
16-07-2008, 21:36 Subject: |
Yes, I bought it new, but initially, it didn't make that much noise either.
Translated on 14-10-2026, 5:15.
Profile PM Email Garage |
TDI-Daniel Blaumann
16-07-2008, 21:40 Subject: |
Disconnect the LDA tube from the T-connector and seal the T-connector.
Is the problem still ongoing? Audi A6 Avant 4B 2,5l TDI AKE
Profile PM Email |
TDI Kraft ohne Ende Guest
17-07-2008, 0:43 Subject: Pressure Measurement: Accurate & Reliable |
Hello paddy84.
Okay, disconnect the vacuum hose that leads to the control unit and blow it through (clamp both ends). Alternatively, run a universal cleaner through it. You're likely to get a lot of oil out; it's a design flaw. In my case, it even caused the system to switch to limp mode under full load (which is quite noticeable when towing a caravan).
Ralph
Translated on 14-10-2026, 5:16.
17-07-2008, 5:44 Subject: Pressure Measurement: A Comprehensive Guide |
TDI Kraft ohne Ende wrote: | | Disconnect the vacuum hose that leads to the control unit and blow it through (clamp both ends), or run a universal cleaner through it. A lot of oil will probably come out; it's a design flaw. In my case, it even caused a switch to the emergency program under full load (it's quite noticeable with a trailer attached). |
So, to be clear, was there a solid, dense plug of oil sludge inside your LD tube, leading to the MSG?
Great story, I'd never heard that before - but it makes sense that the LDR would be acting up. Gruß Ulf
Translated on 14-10-2026, 5:17.
Profile PM Garage |
paddy84
18-07-2008, 17:24 Subject: |
Okay, so... removed the hose and put in a new one. Removed the LDA (likely referring to a Lambda sensor or similar) and installed a new one. It seems to be working; the reading is currently up to 1.1. Does that sound right so far?
Translated on 14-10-2026, 5:18.
18-07-2008, 17:58 Subject: |
paddy84 wrote: | | so... hose out, new one in. LDA out, and new one in as well. Seems to be working, it's maxing out at 1.1 so far. Is that correct so far? | It certainly reads better than your previous posts.  Gruß Ulf
Translated on 14-10-2026, 5:19.
Profile PM Garage |
paddy84
18-07-2008, 18:31 Subject: |
@ ulf , were you able to do anything with the LOG yet?
18-07-2008, 18:41 Subject: |
paddy84 wrote: | | @ulf, were you able to do anything with the LOG? | Not much more than that the pressure spikes were really significant: up to almost 2.5 bar, where the sensor's measurement range ends. Even higher pressure peaks are then only visible on the LDA. Gruß Ulf
Profile PM Garage |
paddy84
18-07-2008, 19:08 Subject: |
Well, as I said, the LDA only goes up to 2 bar.
Hmm, I'll wait and see if he does it again.
Can I purchase the sensor separately from the MSG unit?
I read that Motorola made a similar one, but with 6 pins, and you would only need 3 of them.
Translated on 14-10-2026, 5:20.
paddy84
18-07-2008, 22:51 Subject: |
Hmm, I was happy for nothing. I just left, and he's already started again!
I'm not sure what else I could try. Do you think I should check the VTG? Isn't that the rod that's located underneath the can?
Translated on 14-10-2026, 5:21.
19-07-2008, 9:20 Subject: |
paddy84 wrote: | Well, as I said, the LDA only goes up to 2 bar.
Can I purchase the sensor individually from the MSG (Multi-Sensor Gateway)?
I read that Motorola made something similar, but with 6 pins, and you would need something that only uses 3. | http://shop.dieselschrauber.de/product_info.php/cPath/43/products_id/291
I don't think the sensor is faulty.
Quote: | | Should I check the VTG? Is that the rod that's located under the lid, right? | Yes and yes.
The keyword "injection test" might be helpful if you need more information. Gruß Ulf
Translated on 14-10-2026, 5:22.
Profile PM Garage |
paddy84
19-07-2008, 11:38 Subject: |
"so vtg is easy to use, so it's not the cause of the problem either  "
What kind of connector is this where I have my LDA connected? Should it perhaps be the turbocharger pressure sensor instead?
Translated on 14-10-2026, 5:23.
paddy84
20-07-2008, 16:13 Subject: |
Hi, I might be able to get a VW TDI K04 Garrett turbo at a good price. Would it fit on my car? I've also ordered a new vacuum pump and everything else. I think I've ordered the engine control unit (ECU) too, so hopefully, these problems will be resolved. But the question is, will the turbo fit?
Translated on 14-10-2026, 5:24.
