VCDS TDI Timing: RT & RKS Configuration
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Post23-07-2008, 10:47    Subject: VCDS TDI Timing: RT & RKS Configuration Quote
Hi.
I had my old Golf 3 TDI there again yesterday – it needs to go for its technical inspection (TÜV).
Did both the Ross-Tech 805 and the RKS 805 cause the TDI timing plugin to terminate with a "report error" message being sent to Microsoft?
Any ideas?
Thank you.
Translated on 31-07-2026, 22:16.
Uwe@Ross-Tech
Post24-07-2008, 4:29    Subject: VCDS TDI Timing: RT & RKS Configuration Quote
Windows version?
Computer details?
Could you try a different calculator?
-Uwe-
Translated on 31-07-2026, 22:17.
Post24-07-2008, 10:45    Subject: VCDS TDI Timing: RT & RKS Configuration Quote
Dell Precision M4300.
WinXP
I can still test a Dell Latitude D800 running Windows 2000.
Thank you.
Martin.
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS TDI Timing: No 1Z Support On-Board Diagnostics (OBD)
No new posts AFN is annoyed: TDI timing? On-Board Diagnostics (OBD)
No new posts TDI Graph: Analyze & Optimize Engine Timing On-Board Diagnostics (OBD)
No new posts Fehlbedienung TDI Timing Checker On-Board Diagnostics (OBD)
