Oily intake manifold
dokky
2013 Volkswagen Golf
Post17-07-2008, 13:37    Subject: Oily intake manifold Quote
"I've noticed an increasing amount of knocking during engine operation in my 1.9 MJet 16V. It also vibrates slightly under full load. Because I've detected a diesel smell in the last few days, shortly after turning off the engine, I removed the cover today and took a look." I could not detect any fuel leaks, however, the intake manifold is coated with oil mist on two cylinders near the common rail pump.
Should I have that checked out? Maybe a valve isn't working properly? Or is oil mist after 15,000 km normal?
dokky
Post29-07-2008, 13:55    Subject: Oily intake manifold Quote
Error found. A pipeline was leaking under full load. Now he's purring again.
No new posts AEL - Timing belt oily Diesel Engine Technology
No new posts Detailfragen zur Ansaugbrücke Diesel Engine Technology
No new posts KKK Turbo with intake manifold on AFN Diesel Engine Technology
No new posts Ansaugbrücke 96kW PD-Motor Diesel Engine Technology
