Polo 86C 1.4 Diesel: Reliability & Durability
Gremlin
Avatar-Gremlin
Karma: +91 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post19-08-2008, 13:54    Subject: Polo 86C 1.4 Diesel: Reliability & Durability Quote
Hello everyone,
I'm possibly considering acquiring one of those "pig boxes" with a diesel engine, specifically the 1.4L MKB 1W model, and converting it for use with an LKW (truck) registration (construction vehicle icon_wink.gif).
How durable is this engine? I was thinking about adding a turbo, similar to the Golf2 1V, with about 0.5 bar of boost to give it a little more power, since it already has piston cooling.
Translated on 01-09-2026, 6:15.
Post19-08-2008, 14:59    Subject: Polo 86C 1.4 Diesel: Reliability & Durability Quote
"These items are rarely found by chance."
A JP engine in a Golf 2 would be a much better fit.
I find left-hand threaded injection pumps odd, because with those two timing belts, you have one more place where something can break or become misaligned.
Translated on 01-09-2026, 6:16.
Jens 16syncro
Karma: +2 / -3   Thank you, like it!
Post19-08-2008, 15:53    Subject: Polo 86C Diesel: Reliability and Durability Quote
Gremlin wrote:
I might be interested in getting one of those "pig boxes" with a diesel engine, a 1.4L MKB 1W, and converting it to a truck registration (construction vehicle icon_wink.gif).
How durable is this engine? I was thinking of adding a turbo, similar to a Golf 2 1V, with about 0.5 bar of boost to give it a little more power, and it already has piston cooling.
I once had one of those. When the engine was warm, it was quite usable, at least for those who aren't in a hurry. Retrofitting a turbocharger is complete nonsense; nothing fits together, and the engine won't be able to handle it. There's also hardly any space in the engine compartment.
The ESP doesn't have an LDA (Low-Pressure Diesel Adapter), and without one, I don't consider turbocharger upgrades to be particularly effective. Due to the unusual left-hand thread, you can't install a typical ESP LDA from a 1.6 TD engine.
I would say that installing a turbocharger is not worth it at all.
I think having two timing belts is more of an advantage. It allows for better compensation of the ESP's rotational irregularities and doesn't put additional stress on the timing belt, which is already responsible for driving the camshaft. The 5- and 6-cylinder TD and TDI engines with VTESP also have this feature, and it works very well in those cases.
Jens.
Marcus "Ar Gwenn": Für uns sind Leute arm, weil sie mit einem Eselskarren unterwegs sind, für sie sind wir arm, weil wir ein Leben lang dafür arbeiten und Geld verdienen müssen, um uns im Alter von wildfremden Leuten pflegen zu lassen.
Translated on 01-09-2026, 6:18.
Post19-08-2008, 17:07    Subject: Polo 86C 1.4 Diesel: Reliability & Durability Quote
very good?
I only know one 5-cylinder left-hand drive vehicle... and that's my colleague's AAB Kangaroo.
Der Motor ist sowas von zickig und eigenwillig in seinen Regelaktivitaeten ... Hell.
And the AAB engine is much more closely related to the 1.4 D engine than the computer-controlled TDI engines in the T4.
Translated on 01-09-2026, 6:20.
Jens 16syncro
Post19-08-2008, 17:16    Subject: Polo 86C 1.4 Diesel: Reliability & Durability Quote
I can expand your knowledge icon_wink.gif icon_cool.gif.
CN (Audi 2.0L 5-cylinder naturally aspirated engine) (which is the older predecessor of the AAB).
DE (Audi 2,0l 5-Zyl. WK TD)
NC (Audi 2,0l 5-Zyl. WK TD with LLK)
:028 (VW Industriemotor 2,0l 5-Zyl. WK TD)
AAS (Audi 2.4L 5-cylinder naturally aspirated engine, the direct predecessor to the AAB).
DV (VW 2,4l 6-Zyl. WK TD with LLK)
ACL (VW 2,4l 6-Zyl. WK TD with LLK)
... various other internal combustion engines (ICE) from the 2.4-liter 6-cylinder range.
and the countless 2.5-liter and 5-cylinder TDI variants found in Audi, T4, and LT2 vehicles.
They icon_rolleyes.gif couldn't have all been that terrible.
Jens.
Translated on 01-09-2026, 6:21.
Held467
Post20-08-2008, 20:44    Subject: Polo 86C 1.4 Diesel: Reliability & Durability Quote
Hello.
I also have one of those, and a friend of mine drives one, and it's not bad in that regard, but it's definitely not a sports car.
Technically, it's almost the same as a 1.6-liter engine, but it has the exact same "issues," only the 1.4-liter engine with a "PÖL" system is extremely difficult to start.
The 1.4L engine is turbocharged, and it has a piston cooling system. The fuel pump isn't the problem.
Consider getting a truck with a Telecom approval from the factory.
If you need something bigger, consider a Seat Terra, which also comes with the 1.4-liter engine.
Dirk
Translated on 01-09-2026, 6:24.
Post21-08-2008, 7:50    Subject: Polo 86C 1.4 Diesel: Reliability & Durability Quote
Then, since you say it's not a problem, could you also explain what a turbocharger without an LDA (Linear Differential Amplifier) actually achieves on the ESP (Electronic Stability Program)?
Translated on 01-09-2026, 6:25.
Gremlin
Avatar-Gremlin
Post21-08-2008, 8:42    Subject: Polo 86C 1.4 Diesel: Reliability & Durability Quote
Sure, here's the translation:
"Well,..."
Don't immediately start arguing icon_wink.gif.
"Sure, it's possible to do that, but the performance gain isn't that impressive. With the fuel pump set up correctly, there's a bit of smoke in the low RPM range, which definitely shouldn't happen. At least, that's my experience with the 1V engine in my Golf 2."
The turbocharger, of course, needs to be small enough, something along the lines of a VW Bus T3, specifically the AAZ, RA, or SB engines, or possibly the wastegate turbocharger from the 1Z engine.
I think this issue will probably resolve itself anyway. I received an offer from a colleague for an older Passat Syncro with 90 horsepower, manufactured in 1988 (which still has KE-Jetronik). The idea of an all-wheel-drive vehicle is appealing, especially considering the towing capacity, which is quite high, I believe over 1500 kg with brakes.
Translated on 01-09-2026, 6:26.
Jens 16syncro
Post21-08-2008, 11:26    Subject: Polo 86C 1.4 Diesel: Reliability & Durability Quote
Of course, you can always find a way to make things work, somehow.
It's best not to do a cost-benefit analysis in that situation.
The fact is that vehicles from this Polo series have very little residual value.
Upgrading the 1W engine with a turbo cannot be done simply by using readily available, cheap, off-the-shelf parts from other vehicles, because there are no suitable ones. Therefore, one is forced to create a completely custom solution, including all the associated problems and costs. This starts with the exhaust manifold and doesn't end with the ESP (Electronic Stability Program).
You might do that with a vehicle that's a passion project, but this Polo probably isn't that kind of car.
Therefore: the project is already doomed to fail from the very beginning icon_wink.gif icon_razz.gif.
Translated on 01-09-2026, 6:28.
Gremlin
Avatar-Gremlin
Post21-08-2008, 11:48    Subject: Polo 86C 1.4 Diesel: Reliability & Durability Quote
I see it that way now too. It's not really a vehicle for enthusiasts, as you said, and you can't do much with it in terms of carrying capacity. Of course, durability is another matter. When I look at the tiny connecting rod bearings, I can tell that it's not going to last.
"Nevertheless, thank you for the quite numerous responses!"
Translated on 01-09-2026, 6:29.
Uli S.
Post21-08-2008, 16:22    Subject: Polo 86C Diesel: Reliability and Durability Quote
Jens 16syncro wrote:
Due to the exotic left-hand thread, it is not possible to install a typical LDA (Left-hand Drive Adapter) on a 1.6 TD ESP.
Why not? Or, to put it another way, which components in the left-hand pump interfere with the 1.6-liter pump cover or the LDA (Lambda-regulated direct injection) function?
I would say: Installing Turbo is not worth it at all
I agree with you.
Best regards, Uli.
Golf2 GTD AAZ, LLK, CYP
Bus T3 JX
2x Golf2 GTD/SB
97er Golf 3 AFN, 70-100% Pöl
97er Golf 3 Variant AFN
96er Passat 35i AFN
Translated on 01-09-2026, 6:30.
Held467
Post21-08-2008, 18:36    Subject: Polo 86C 1.4 Diesel: Reliability & Durability Quote
The lid is different; it's missing some holes.
The G40 also works well with the "mini" bearings, even when delivering a lot of power.
Translated on 01-09-2026, 6:31.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post23-08-2008, 21:49    Subject: Polo 86C 1.4 Diesel: Reliability & Durability Quote
My colleague just received one of those as a gift.
With 540,000 km on the odometer. Besides the head gasket, nothing else has been replaced.
From my point of view, there's nothing against gentle tuning.
Because if it can achieve such impressive engine power, then with better oil and a truly moderate 0.5 bar of pressure, the engine will likely last for hundreds of thousands of kilometers.
since he doesn't always have to be driven at his limit here, just like with the 45 horsepower.
"He's also asking me if it uses the same connecting rod bearings as the 1.9."
Translated on 01-09-2026, 6:32.
Held467
Post23-08-2008, 22:51    Subject: Polo 86C 1.4 Diesel: Reliability & Durability Quote
No, warehouses are different.
There's one with a G40 turbocharger that, with the original fuel pump, produced 73 horsepower.
Translated on 01-09-2026, 6:33.
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts The fine particulate matter disaster and diesel engines w... Technical Articles
No new posts DPF-Diesel and GSKs, Glow Plug Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diesel - Zero Point? - Durability of Diesel Engines Diesel Engine Technology
No new posts Polo diesel with a gasoline transmission??? Diesel Engine Technology
No new posts Speedometer for Polo 6N Diesel 1998 1.9 TDI Electrical Systems, Vehicle Electronics, Multimedia
No new posts Polo 9N3: Can I actually measure the amount of diesel bei... Diesel Engine Technology
