Audi TDI AEL exhaust manifold cracked - consequences?
TDI-Quattro
Post28-09-2008, 10:51    Subject: Audi TDI AEL exhaust manifold cracked - consequences? Quote
Hi, I changed the diesel filter yesterday, and then when I tried to start the engine to fill it up, I noticed that it's smoking from somewhere in the front.
While inspecting, I discovered the cracked exhaust pipe. The crack goes all the way around, and when starting the engine, the turbo moves up to the crack, and the smoke escapes from there. When the engine is running, there is no abnormal noise, and when the engine is idling, no exhaust gases escape. It's clearly visible in the photo.
[img][/img]
Could this crack be causing poor performance in the upper area? I think so?
What further impacts could the crack have?
Thank you for the information.
It will be welded soon, but I didn't manage to do it this weekend.
Cheers.
Thomas.http://www.freitachnacht.de/Hosenrohr_Riss1.jpg{MARKER}
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post28-09-2008, 14:28    Subject: Audi TDI AEL exhaust manifold cracked - consequences? Quote
The crack certainly has no impact on the performance. It's too small for that.
Possibly, the cat is lost. This would become noticeable at high speeds.
He would likely whistle loudly from the crack under full load.
Based on how the crack looks, it should be possible to weld it.
When you're taking apart the catalytic converter, check to see if it's clogged.
No new posts Auswirkungen von Adaptionen? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB AMF Error Codes: Causes and Effects Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error Codes, Causes and Effects for MKB ASZ, AXR, ATD Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM Values: Meaning and Impact Diesel Engine Technology
This topic is locked, you cannot edit or reply. VEP-TDI Nozzles: Available Options & Effects Diesel Engine Technology
No new posts Defective ZMS: Effects and Troubleshooting Diesel Engine Technology
No new posts Track Width: Impact on Vehicle Handling Transmission, Chassis, Body & Interior
