Galaxy Fan Starts Immediately After Engine Start (98-02)
papa-joe
Post12-10-2008, 7:56    Subject: Galaxy Fan Starts Immediately After Engine Start (98-02) Quote
Hello!!
Could it be unusual that, when starting my Galaxy's engine in low outside temperatures, the electric fan immediately turns on? If I turn off the climate control (eco mode), it turns off - there are no error messages in the control unit! The temperatures in block 1 are all the same and correspond to the outside temperature!
My old Passaf AFN, which previously had Climatronic, didn't do that before!
It doesn't really bother me, but I feel sorry for the expensive fans somehow!
Best regards, Josef.
Translated on 12-10-2026, 8:35.
michiglaser
2007 Audi A4 Avant
Post12-10-2008, 11:18    Subject: Galaxy Fan Starts Immediately After Engine Start (98-02) Quote
The purpose of the continuously running fan when the air conditioner is on is to allow the air conditioner's condenser to dissipate heat (allowing the refrigerant to transition from a gaseous to a liquid state).
I doubt your Passat didn't do that (if everything was alright).
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 12-10-2026, 8:36.
Post13-10-2008, 15:15    Subject: Galaxy Fan Starts Immediately After Engine Start (98-02) Quote
papa-joe wrote:
My old Passat AFN with Climatronic didn't do that before!
Then something wasn't right with the Passat.
Use the search function and you'll see that it's normal.
Translated on 12-10-2026, 8:37.
No new posts MKB ABC: Engine Start Issues After MSG Replacement Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3BG AVB - Remove bearing from Visco fan Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Issue: A3 (98+) - Not Centered on ESP Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fan Always Running? Troubleshooting Guide Diesel Engine Technology
No new posts Blue smoke on engine start Diesel Engine Technology
No new posts Engine Start Problem: Strange Issue? Diesel Engine Technology
This topic is locked, you cannot edit or reply. Check Engine Light On After Start? Diesel Engine Technology
