Audi AEL 4A0907401P Login 12233 falsch? | Posts 16+
Go to page: Previous  1, 2
dakoal
Post07-08-2006, 10:54    Subject: Quote
Hi, I already have one drive installed, but I just wanted the "icing on the cake". icon_twisted.gif
Sure, here's the translation:
"Best regards," or "Sincerely,".
dakoal
P.S. It's not going to work for me anyway.
Rainer K. wrote:
There's no login functionality on your STG.
Best regards, Rainer
____________________________________
Audi A6 Avant (C4) 2,5TDIi MKB:AEL, BJ 1995 @ 220tkm //www.spritmonitor.de/image_116461_1.png
VW Golf III 1,9D MKB:1Y, BJ 1995 @ 182tkm R.I.P. (Rest in Poland)
Translated on 11-09-2026, 21:41.
Back to top Profile PM Email
PAPPL
Post03-07-2007, 6:16    Subject: Quote
I also wanted to reduce the AGR rate through login within the AEL system.
Keiner der Login-Codes funktioniert beim 1995er AEL quattro. Die Verbindung reisst nach der Codeeingabe ab. Zündung aus und an und Vag-Com neu starten dann ist die Verbindung wieder da. Help!
"Okay, I was finally able to log in. I had a value of 128 saved for channel 3, which can be increased to a maximum of 136. So, the AGR rate is decreasing. What I don't quite understand is: Does this have any effect on the boost pressure curve?"
Es wäre so einfach, ist es aber nicht!
Translated on 11-09-2026, 21:42.
BladeRunner
Post19-10-2008, 16:34    Subject: Quote
Sorry, no German, but I found the login for AEL today, so I'm putting it here because it's a topic I found while searching for it, and it's not here. icon_cool.gif
AEL Login = 22158
Translated on 11-09-2026, 21:43.
No new posts Documentary: Octavia 1 / Golf IV fuel gauge malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Login Codes TDI / VAG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fuel Injection Timing Off? Diesel Engine Technology
No new posts Jack incorrectly positioned, what now? Transmission, Chassis, Body & Interior
No new posts Control: 77 incorrectly encoded, FSE 5K0 035 730 E Electrical Systems, Vehicle Electronics, Multimedia
No new posts Cold start problem: Incorrect injection timing? Diesel Engine Technology
