Fuel Injector Solenoid: Insufficient Voltage
Siegfried Weber
Post26-10-2008, 13:22    Subject: Fuel Injector Solenoid: Insufficient Voltage Quote
Hello, I drive a 1990 Audi 100 TDI with a 2.5-liter engine.
Here's the problem. The preheating indicator doesn't turn off completely; it continues to glow. This error initially occurred sporadically and usually resolved itself if the vehicle was parked for a certain amount of time. There was only about 5 volts at the glow plug relay. When I directly supplied the relay with 12V, the engine started immediately. Now, the error occurs constantly, and the turbocharger is no longer engaging. The vehicle can only be driven by directly supplying 12V to the relay and without turbo assistance.
Who has advice?
I am grateful for any suggestions.
Wishing you always a safe and pleasant journey:
Siegfried Weber.
Translated on 06-10-2026, 13:11.
Post26-10-2008, 17:03    Subject: Fuel Injector Solenoid: Insufficient Voltage Quote
Siegfried Weber wrote:
Audi 100 TDI, 2.5 l engine, manufactured in 1990. The solenoid valve was only receiving approximately 5 volts. When I directly supplied the solenoid valve with 12 volts, the engine started immediately. Now, this problem occurs constantly, and the turbocharger is no longer engaging. Driving is only possible by directly supplying 12 volts to the solenoid valve and without turbocharger assistance.
Wer weiß Rat??
Hast Du den 5Zyl. Engine with VP37?
I suspect a transition resistance in the MSG supply could be the common cause. In the case of the 1.9 models, the main relay (109) is often the culprit.
Translated on 06-10-2026, 13:13.
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0046 - Turbocharger Boost Control Circuit Malfunction, M... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts RWG Voltage High: No Gas Intake - Help! On-Board Diagnostics (OBD)
No new posts LED Headlights: Bright & Powerful Transmission, Chassis, Body & Interior
No new posts Gas Pedal Sensor Voltage Reading Diesel Engine Technology
No new posts Golf 4: Low AC Compressor Pressure - Troubleshooting Transmission, Chassis, Body & Interior
