Passat 3BG Towing Hitch doesn't fit?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Tribu
Karma: +3 / -2   Thank you, like it!
Post02-11-2008, 16:55    Subject: Passat 3BG Towing Hitch doesn't fit? Quote
Hi @ all....
"Bitte geben Sie Ihren Namen, Ihre Adresse und Ihre Telefonnummer an. {NAME} {ADRESSE} {TELEFONNUMMER} Vielen Dank für Ihre Kooperation."
I bought a tow hitch supposedly for a VW Passat 3BG (very cheap), but now it needs to fit into the frame from the back. The coupling must be mounted with 3 bolts on each side.
The frame measures approximately 7*7 cm (per side), but the coupling is only 4*4 cm. Is there a missing adapter, or is this incorrect? That would be quite a mess.
Who knows what? I know the description is very vague. The Passat is from 2003.
No new posts Passat 3C air conditioning not cooling General Tips
No new posts Doku Passat MKB AVB, Kraftstoffverlust Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Werkstattaktion Ladeluftschlauch, Passat B5, 74/96 KW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Twintec DPF does not fit properly in Passat 3BG - it make... Diesel Engine Technology
No new posts Welches STG passt in meinen Passat 1Z? On-Board Diagnostics (OBD)
No new posts Piston at top dead center does not align with crankshaft ... Diesel Engine Technology
This topic is locked, you cannot edit or reply. Passat 3BG 1.9 TDI not starting/won't start due to glow p... Diesel Engine Technology
