Finding the Mysterious Error: Troubleshooting Guide
Das Unwissen
Avatar-Das Unwissen
Post01-11-2008, 15:31    Subject: Finding the Mysterious Error: Troubleshooting Guide Quote
"Good day, I'm new here and, coincidentally, I have a problem. So, here's the issue... my engine is running rough at idle, and the fuel consumption is constantly 10.9 liters, regardless of driving style (sporty/economical), and the instrument cluster is not defective. The fuel injectors are leaking evenly (all four, so I'm ruling out a leaky seal), which means there's fuel residue accumulating around the injectors on the intake manifold. Starting the engine is very unstable; if you don't give it a little more gas, the engine tends to stall, and the RPM drops significantly. When shifting gears, the throttle response feels like I'm being hit with a hammer (unharmonious). I hope you can help me. Here's some more information: it's an A3 (8L) with engine code AJQ, 1.8T. I also have a diagnostic tool and have created log files from all the engine management data blocks (while driving and at idle). So, if you need a specific data block for comparison, I can send it to you to help narrow down the problem. That's all for now, and I hope you can help me."
Translated on 12-10-2026, 8:29.
schrauber84
Karma: +1 / -1   Thank you, like it!
Das Unwissen likes this.
Post02-11-2008, 8:45    Subject: Finding the Mysterious Error: Troubleshooting Guide Quote
Please include the measurement values here. You might get help that way.
Translated on 12-10-2026, 8:30.
Das Unwissen
Avatar-Das Unwissen
Post02-11-2008, 15:42    Subject: Measurement Data: Share Your Results Here! Quote
Friday, October 31, 2008, 16:35:54.
06A 906 032 BB 1.8L R4 5VT 0004
Group A: 000
Translated on 12-10-2026, 8:31.
Post02-11-2008, 16:13    Subject: Finding the Mysterious Error: Troubleshooting Guide Quote
"More isn't always better. Please upload the raw CSV files as attachments. And please don't include data recorded under arbitrary conditions, but rather data relevant to the specific problem area, ideally under full load and idle conditions."
See How to Properly Record and Analyze VAG-COM/VCDS Log Files.
Translated on 12-10-2026, 8:32.
Das Unwissen
Avatar-Das Unwissen
Post02-11-2008, 16:25    Subject: Finding the Mysterious Error: Troubleshooting Guide Quote
Yes, that's correct. That's why I asked which block you need. I didn't want to overwhelm you with information (sorry about that). Unfortunately, I don't have full load capacity, only 2000 RPM to 3500 RPM... sorry, I'm not very familiar with this yet, but I do have an idle option available. Which block do you need?
Translated on 12-10-2026, 8:33.
No new posts Caddy Bj 07 BLS AGR Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0148 - Fuel Supply Malfunction General Tips
No new posts TDI 1Z Glow Plug Fuse Troubleshooting Diesel Engine Technology
No new posts Battery: The Quest for Energy Electrical Systems, Vehicle Electronics, Multimedia
No new posts OT Mark Location on Flywheel Diesel Engine Technology
No new posts Defective Engine Control Unit: Find Replacement ECU On-Board Diagnostics (OBD)
