Turbocharger Pressure: How Much Is Too Much?
VWGOLFIII
Post01-04-2003, 15:07    Subject: Turbocharger Pressure: How Much Is Too Much? Quote
Hello.
Can anyone tell me what the original turbocharger boosts to? (0.5 bar?)
For my TD, not TDI!
Thank you, and best regards, Mark.
Translated on 23-09-2026, 12:48.
Michael II
Post01-04-2003, 15:18    Subject: Turbocharger Pressure: How Much Is Too Much? Quote
It should be between 0.6 and 0.83 bar.
Tschüss
Michael II
Translated on 23-09-2026, 12:49.
VWGOLFIII
Post01-04-2003, 20:02    Subject: Turbocharger Pressure: How Much Is Too Much? Quote
Stefan
Post03-04-2003, 7:04    Subject: Turbocharger Pressure: How Much Is Too Much? Quote
I used to own an FJ1200 myself, but how did you arrive at 150 horsepower?
VWGOLFIII
Post03-04-2003, 18:20    Subject: Turbocharger Pressure: How Much Is Too Much? Quote
Hi.
Okay, if you want to get more power (horsepower) by using a different camshaft, exhaust system, and Dyno-Jet, and if you want even more, then the engine needs to be completely disassembled, bored out to a larger size, and have a higher compression ratio.
Translated on 23-09-2026, 12:50.
Gremlin
Post03-04-2003, 19:38    Subject: Turbocharger Pressure: How Much Is Too Much? Quote
I once had an FJ1200, but how do you get to 150 horsepower ???
Huh? They're already easily getting 600 [points/scores/etc.]...
As he already mentioned... just some minor work...
CU Gremlin.
Translated on 23-09-2026, 12:51.
Rudi
Post03-04-2003, 19:48    Subject: Turbocharger Pressure: How Much Is Too Much? Quote
... we could ask Rainer if he could create a section, maybe called 'A Diesel Mechanic's Summer Delights' or something similar... icon_biggrin.gif
But this is really going off-topic now.
Best regards, Rudi.
Translated on 23-09-2026, 12:52.
No new posts Turbocharger Repair 1.9 TDI ASZ Troubleshooting & Guides
No new posts Transporter 7D Turbocharger Pipes: ACV Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Whistle: Documentary Analysis Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tire Pressure Monitoring System (TPMS) Coding On-Board Diagnostics (OBD)
No new posts Charging Air Temp/Pressure Sensor: Do You Have It? On-Board Diagnostics (OBD)
No new posts AKU engine size: How many cc? Diesel Engine Technology
No new posts KGE: How much oil leakage is normal? Diesel Engine Technology
