P1854: Drive Hardware Fault - Data Bus Error 18262
mpreugsc
Post07-12-2008, 15:50    Subject: P1854: Drive Hardware Fault - Data Bus Error 18262 Quote
"I recently received this error message from the engine control unit (ECU) of my 1998 Volkswagen Golf IV 1.9 TDI."
Can someone tell me what that's all about?
The engine itself functions normally.
Translated on 13-10-2026, 12:20.
axmax
Post10-12-2008, 12:58    Subject: P1854: Drive Hardware Fault - Data Bus Error 18262 Quote
Given the year of manufacture, the CAN bus should actually be irrelevant, as everything is still connected in a conventional way. Does your ABS system use a CAN bus? I could imagine that the ABS might be connected to the engine control unit (ECU) via CAN, but I don't really think so.
The instrument cluster is certainly not connected to the engine control unit (ECU) via CAN. The latter can already support CAN, because it was designed for future model years. I would actually say, if it does everything... it's good icon_smile.gif.
Audi A4 B6 BFC
Translated on 13-10-2026, 12:21.
No new posts Document: Lack of power during cold starts with 2.5 engin... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Subaru Diagnostics: Using VCDS Hardware Troubleshooting & Guides
No new posts Parking Assist Fault: Audi A6 (4B) Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 005769 - Data bus driver P1689 - 000, 049472 - Body contr... Diesel Engine Technology
No new posts Data Bus Software Status Monitoring: Error 18263 On-Board Diagnostics (OBD)
No new posts AKN Injection Pump Fault On-Board Diagnostics (OBD)
No new posts Audi A8 Trailer Hitch Coding - Data Bus Error On-Board Diagnostics (OBD)
