Trabold Side Channel Filters: Specs & Performance
MeisterEIT
Post04-04-2003, 22:35    Subject: Trabold Side Channel Filters: Specs & Performance Quote
hi,
Does anyone have experience with Trabold filters?
I mean, if you install it and change the oil normally, it definitely can't be worse than it was before.
But what about the extended oil change intervals?
It is said that the oil can last for 100,000 kilometers without needing to be changed.
The standard filter should normally be replaced every 15,000 km.
Has anyone installed a differential filter like this before?
greetings
Translated on 14-10-2026, 1:50.
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post05-04-2003, 12:24    Subject: Trabold Side Channel Filters: Specs & Performance Quote
Hi!
I don't entirely trust the system, but here: http://www.2literauto.de/Subjektiv/Verschleiss/verschleiss.html
Has anyone installed this in their 3L Lupo and documented the process?
brezelmann01
Translated on 14-10-2026, 1:51.
diesel.gustav
Post05-04-2003, 20:48    Subject: Trabold Side Channel Filters: Specs & Performance Quote
Deleted upon request.
Translated on 14-10-2026, 1:52.
No new posts trabold - filter Diesel Engine Technology
No new posts What are they anchored to? Diesel Engine Technology
No new posts .clb Files: What are they and how to open? On-Board Diagnostics (OBD)
No new posts Rim Damage: Causes and Repair Options Transmission, Chassis, Body & Interior
