interpares wrote: |
hi... and I noticed that there are air bubbles in the main fuel line, the one you can see, and when it's idling,
Where does the damn air come from? Error codes = nothing |
Hi, so it's not normal to have an air bubble, although a "very small" one might not make a difference.
Have you ever searched for "starting problem" or "air bubble" in the search bar?
If the glow plugs and battery are working correctly, then the air (e.g., a leak in the air line, a blocked air intake, a clogged diesel filter) is likely your problem. Connect the intake line directly to a diesel container and leave it connected, then try to start the engine
