Andy Guest
11-04-2003, 18:49 Subject: Removing the Climatronic control unit from a Volkswagen Golf 3 |
What tricks and techniques should be considered to remove the Climatronic control unit as a component from the dashboard?
Best regards, Andy.
Translated on 19-07-2026, 20:46.
Varianti Guest
14-04-2003, 15:13 Subject: Removing the Climatronic control unit from a Volkswagen Golf 3 |
What's the problem?
First, carefully pry off the control panel from all sides. Then, loosen and remove the four screws and pull it out. If that doesn't work, completely unscrew the frame (where the ashtray is located). This will give you easy access.
Actually, it's quite simple. I've never had any problems with it.
Translated on 19-07-2026, 20:47.
Andy Guest
14-04-2003, 15:47 Subject: Removing the Climatronic control unit from a Volkswagen Golf 3 |
Thank you for the information.
Just wanted to check beforehand if anything is likely to break easily.
Broken plastic hooks are always annoying.
Best regards, Andy.
Translated on 19-07-2026, 20:48.
