VP37 High-Pressure Pump Replacement
Jürgen
Post13-05-2009, 20:48    Subject: VP37 High-Pressure Pump Replacement Quote
I have a few questions for those of you who have already replaced a high-pressure pump (pump head and piston).
- Is the large end cap already installed in the new pump, or does it need to be taken from the old one?
- Are there any specific considerations regarding the start of injection or the amount of fuel injected, and how these should be adjusted?
'I've disassembled and resealed pumps before, including those on flow meters; it's not rocket science. I also have all the necessary tools and equipment, as well as a full version of VAG-COM.'
Translated on 24-09-2026, 6:19.
Post13-05-2009, 21:35    Subject: VP37 High-Pressure Pump Replacement Quote
Replacing it while it's installed is tricky... it's better to remove it and position it vertically. Make sure the spacer for the pump piston is properly positioned and has the correct thickness.
Translated on 24-09-2026, 6:20.
Jürgen
Post13-05-2009, 22:12    Subject: VP37 High-Pressure Pump Replacement Quote
Rainer,
I have removed all the pumps that I have worked on so far. I don't believe in doing any work on pumps while they are installed, especially since the removal process is actually quite quick.
My question mainly concerns the necessity of any measurement or adjustment procedures. Somewhere (I can't remember where!), I once read something about calibrating the HD pump. However, I can't quite figure out how that would work based on the way the VP37 functions.
Translated on 24-09-2026, 6:21.
Post13-05-2009, 22:31    Subject: VP37 High-Pressure Pump Replacement Quote
With the pump fully extended, the piston must not hit the front.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post14-05-2009, 10:01    Subject: VP37 High-Pressure Pump Replacement Quote
The large central screw is not included with the new HD part.
However, I would never reuse the old one, but would buy a new one (5 euros).
Because I had already experienced terrible problems with this screw.
The in-situ replacement would be my preferred option, as I've done it approximately 10 times before.
If you approach the task carefully, it is very safe and you can save a lot of time.
Translated on 24-09-2026, 6:22.
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts 2.0 TDI Timing Belt Replacement - High-Pressure Pump Misa... Diesel Engine Technology
No new posts Low rail pressure. - Defective high-pressure pump? Gasoline Engine Technology
No new posts High-Pressure Pump Timing: Why It Matters Diesel Engine Technology
No new posts High-pressure pump screw sheared off, need help Diesel Engine Technology
