Passat AVF: High Fuel Consumption Explained
ristici
Post04-03-2009, 11:22    Subject: Passat AVF: High Fuel Consumption Explained Quote
"My Passat AVF automatic is consuming too much fuel, 12 liters per 100 km with normal driving. The air filter and mass airflow sensor are new. After an "Spritspar-Tuning" adjustment, the fuel consumption decreased slightly, but only at speeds of 120 km/h and above. Below 120 km/h, the fuel consumption is still high."
How can I use VAG-COM to find errors or read/correct the fuel injection timing?
The car has 162,000 kilometers on the odometer.
Ristic.
Translated on 12-10-2026, 15:20.
Post04-03-2009, 11:32    Subject: Passat AVF: High Fuel Consumption Explained Quote
First, I would check the coolant temperature reported to the engine control unit, then look for leaks in the charge air system. Cracked rubber hoses are a common problem here.
Rest: See search function...
Translated on 12-10-2026, 15:21.
BM
Avatar-BM
Post04-03-2009, 14:39    Subject: Passat AVF: High Fuel Consumption Explained Quote
Stuck brake pads (rear) also cost 1/2 liter of fuel.
3B5 AJM
Translated on 12-10-2026, 15:22.
Post04-03-2009, 15:11    Subject: Passat AVF: High Fuel Consumption Explained Quote
12 liters per 100km... hmm, does that mean the automatic transmission is also stuck in 3rd gear?
Post04-03-2009, 22:25    Subject: Passat AVF: High Fuel Consumption Explained Quote
12 liters /100 KM icon_eek.gif icon_eek.gif I would never be able to achieve that, not even if I attached my living room to the back!
Does the car automatically brake when coasting?
Automatic system in emergency mode?
Automatic transmission shifts very late - high RPMs?
Are the tires properly inflated?
Automatic transmission fluid level, OK?
When was the last time the automatic transmission fluid (ATF) was changed, including the filter? Even though it's supposedly never supposed to be changed, it can work wonders!
Timing belt tension, 100% correct?
Is the fuel return cooler leaking at the bottom?
Translated on 12-10-2026, 15:23.
ristici
Post05-03-2009, 11:28    Subject: Passat AVF: High Fuel Consumption Explained Quote
The brakes are in good working order.
The automatic transmission seems to be shifting normally, but I need to check if it's in a limp mode. Good idea!
I don't know if the timing belt tension is correct; I'll check that next week.
Last month, the car was at a Bosch service center, and they said the injection duration was too long, and they replaced the third fuel injector.
Thank you for your help!
Ristic.
Translated on 12-10-2026, 15:25.
scrdel
Karma: +4 / -2   Thank you, like it!
2002 Volkswagen Passat
Post17-03-2009, 19:49    Subject: Passat AVF: High Fuel Consumption Explained Quote
... if the automatic transmission is in limp mode, you can immediately tell by the completely red illuminated gear indicator on the speedometer, or you'll notice it even faster because the car will only be in fourth gear, making it feel like chewing gum.
Sven.
Translated on 12-10-2026, 15:26.
Post17-03-2009, 20:41    Subject: Passat AVF: High Fuel Consumption Explained Quote
ristici
Post25-03-2009, 20:57    Subject: Passat AVF: High Fuel Consumption Explained Quote
No, that didn't help.
We have now adjusted the injection timing, and as a result, the average fuel consumption is now 2 liters lower.
But still 10 liters per 100 kilometers... that's too much icon_sad.gif.
The gears are shifting properly!
Ristic.
Translated on 12-10-2026, 15:27.
ristici
Post28-05-2009, 17:36    Subject: Passat AVF: High Fuel Consumption Explained Quote
hello,
I've created some logs, and it would be great if someone could take a look at them.
I'm not sure if I did the logs correctly.
best regards
ristic
LOG-01-001-003-015.CSV
 File name:  LOG-01-001-003-015.CSV
 File size:  24.02 KB
 Downloaded:  627 times
LOG-01-001-003-011.CSV
 File name:  LOG-01-001-003-011.CSV
 File size:  19.58 KB
 Downloaded:  555 times
LOG-01-001-003-010.CSV
 File name:  LOG-01-001-003-010.CSV
 File size:  8.12 KB
 Downloaded:  522 times
Translated on 12-10-2026, 15:28.
Post28-05-2009, 21:34    Subject: Passat AVF: High Fuel Consumption Explained Quote
It would be better to restore your smoker to its original design. Everything that comes out the back as smoke is just unburned fuel.
Looking at some of the things in the log, I'm feeling sick. This has nothing to do with chip tuning, but rather with sloppy work. Also, please read the instructions on how to create a log (see the "Upload Subforum").
No new posts Audi A3 (8L): High Mileage Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: High oil consumption, AFB and AKN engines Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Crafter, Year 2012/2013, High Standby Current Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts High fuel consumption on Passat with AJM engine and Tiptr... Diesel Engine Technology
No new posts Passat 1.9 TDI AVF Vibrationen, Ruckeln und hoher Verbrauch Diesel Engine Technology
No new posts Poor cold start, misfires, high diesel consumption - Passat Diesel Engine Technology
No new posts High consumption, normal performance Diesel Engine Technology
