ESP: The "Dirty Screws" Explained
Tribu
Karma: +3 / -2   Thank you, like it!
Post01-06-2009, 22:08    Subject: ESP: The "Dirty Screws" Explained Quote
I meant triangular icon_biggrin.gif, of course.
Does anyone have any ideas on how to remove it without damaging it and using the right tools?
The reason is the replacement of the G81 temperature sensor.
Golf IV diesel...
I thank you...
Translated on 10-08-2026, 11:47.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post02-06-2009, 0:59    Subject: ESP: The "Dirty Screws" Explained Quote
I used a small hand coping saw to cut a slot, and then I unscrewed the relatively loose screw with a screwdriver. I think that's the fastest method.
reflexsilber met.
Translated on 10-08-2026, 11:48.
wolfi_b
Post02-06-2009, 9:00    Subject: ESP: The "Dirty Screws" Explained Quote
Or file down a nut (I think it's a size 7) on three surfaces to create a rounded edge.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 10-08-2026, 11:49.
vc
Post02-06-2009, 14:51    Subject: ESP: The "Dirty Screws" Explained Quote
The triangular screws are 'supposedly' used to secure explosion-proof enclosures (Ex protection class D) against unauthorized access, so they are being used for a slightly different purpose here.
So, for example, you can obtain special screwdrivers (the keyword here is 'ex-cutlery') from online marketplaces; these are readily available for purchase, and then everything is quiet.
Tribu
Post02-06-2009, 22:27    Subject: ESP: The "Dirty Screws" Explained Quote
Okay, thank you for your tips. Well, then I'll try to crack the ESP case. "Ex cutlery" sounds good, sawing is the easiest, and the one with the nut sounds like the best option icon_smile.gif.
There's something for everyone, and I'm looking forward to Saturday...^^
Thank you very much.
Translated on 10-08-2026, 11:50.
Tribu
Post06-06-2009, 21:43    Subject: ESP: The "Dirty Screws" Explained Quote
It fit perfectly with a size 7 nut. I carefully hammered the nut onto the exposed screw, and then it was easy to unscrew.
And again, money saved through the forum icon_biggrin.gif.
Thank you...
Translated on 10-08-2026, 11:51.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 08/01 MKB "AVF" GKB "EYF" Getrieb Diesel Engine Technology
No new posts Austausch des RNS315 gegen neues "Discover Media" Electrical Systems, Vehicle Electronics, Multimedia
No new posts Injector Nozzles: Can You Repair the "Tips"? Diesel Engine Technology
No new posts Euro 4 requirement not as "absolute" as previously thought? Diesel Engine Technology
