Longlife Oil: How to Code It?
Wiesel
Post11-06-2009, 18:38    Subject: Longlife Oil: How to Code It? Quote
A friend of mine bought a used Volkswagen Golf 5 last year.
A service was performed - according to the manufacturer's longlife interval.
Now, after almost 15,000 kilometers, the car... you guessed it... needs servicing.
Supposedly, it's because she mostly drives in the city icon_confused.gif.
I have reviewed the relevant adaptation channels today.
Code:
Kanal 40 (gefahrene Wegstr. seit letztem Service) Wert: 149 -> 14.900km
Kanal 41 (Zeit seit letztem Service)              Wert: 368 -> 368 Tage
Kanal 42 (minimale km-Fahrleistung)               Wert: 150 -> 15.000km
Kanal 43 (maximale km-Fahrleistung)               Wert: 300 -> 30.000km (fest: 150, variabel: 300)
Kanal 44 (maximales Zeitintervall)                Wert: 744 -> 744 Tage
Kanal 45 (Ölqualität)                             Wert: 2 (fest: 1, vaiabel: 2)
Kanal 49 (minimales Zeitintervall)                Wert: 372  (fest: 365, variabel:730)
Everything fits with the variable interval... except for channel 49.
According to OpenOBD, it should be above 730 (presumably referring to a measurement value).
Was war es also wirklich: ihr tatsächliches Fahrverhalten (und damit die Information, die Open OBD anzeigt), oder...
Does the forgotten (?) channel 49 overpower everything else?
If the time interval follows the same logic as the mileage, then a year would be...
Also suitable for long-life oil (but definitely not before).
Best regards, Micha.
Translated on 06-09-2026, 9:28.
Post12-06-2009, 6:02    Subject: Longlife Oil Change: How to Do It Right Quote
Hi Micha,
Based on my recollection of the Polo (which I now drive with fixed intervals), the recorded data for time and mileage included "logical" minimum and maximum values. Therefore, the data being read out seems correct, and there appears to be an error in Open OBD.
For your consolation: Your acquaintance is not an isolated case. For example, in the 9N.info forum, many drivers also complain about variable intervals that are actually almost as short as fixed intervals.
Translated on 06-09-2026, 9:30.
Wiesel
Post12-06-2009, 7:14    Subject: Longlife Oil Change: How to Do It Right Quote
ulf wrote:
... it seems there is a bug in Open OBD.
It seems so to me too.
To offer some comfort: Your acquaintance is not an isolated case. For example, in the 9N.info forum, many drivers also complain about variable intervals that are actually almost as short as fixed intervals.
I'm afraid that if he had been allowed to, the lamp would have been turned on earlier.
(which, however, was prevented by the values in channel 42 and 49).
It looks like there might be a bug in the software (at least with the gasoline models).
in the calculation of the time / distance until the next service icon_twisted.gif.
It's really unacceptable that he's using that expensive long-life oil.
...just goes as far as it would with regular, inexpensive oil.
Translated on 06-09-2026, 9:32.
Post12-06-2009, 8:00    Subject: Longlife Oil Change: How to Do It Right Quote
Wiesel wrote:
It's really unacceptable that he's using the expensive long-life oil.
It just goes as far as normal "cheap oil".
From a consumer's perspective: yes.
Translated on 06-09-2026, 9:33.
Wiesel
Post12-06-2009, 8:38    Subject: Longlife Oil: How to Code It? Quote
"Evil befalls those who do evil..." or something like that icon_wink.gif.
Translated on 06-09-2026, 9:34.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post12-06-2009, 8:44    Subject: Longlife Oil: How to Code It? Quote
The oil must be bought; buy 5 liters for 40.- icon_biggrin.gif.
No, yesterday I also set my Touran's mileage check to another 15,000 km... the next one is at 90,000 km. ha icon_cool.gif
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
mserge
Post15-06-2009, 15:36    Subject: Longlife Oil: How to Code It? Quote
It's better to change the oil too often than not enough. What's 40 euros compared to engine damage? Change the oil, then switch channel 49, and drive until it alerts you again. It'll be fine.
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 06-09-2026, 9:35.
No new posts VAG Longlife Oil Standards Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Longlife Service: Your Best Choice Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Some information about the longlife service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Longlife III Diesel Engine Technology
No new posts Long Life Engine Oil for AJM Engines Diesel Engine Technology
No new posts Long Life Service: Your Car's Extended Warranty On-Board Diagnostics (OBD)
No new posts Longlife Oil for VP-TDI Engines Diesel Engine Technology
