2-Stroke Oil: Break-in & Best Practices
neudiesel
Post28-04-2003, 18:27    Subject: 2-Stroke Oil: Break-in & Best Practices Quote
I expect to receive my 130HP PD unit within the next few days, and of course, I want to use it.
I need to break it in properly, as it's my first diesel car.
I had only driven gasoline cars before.
A colleague told me that he used to add one liter of two-stroke oil to each tank of diesel in his older vehicles, saying it was an old trick.
Has anyone had similar experiences? Can anyone give me some advice?
I've already checked the FAQ section, but it doesn't provide enough information.
Who is better suited for gentle break-in and who is better suited for a more aggressive break-in?
Translated on 01-11-2026, 7:43.
wuze60
Post28-04-2003, 18:54    Subject: 2-Stroke Oil: Break-in & Best Practices Quote
So, let's properly break it in icon_wink.gif:
I would say it's best to drive at a normal speed, somewhere between 2000 and 3000 RPM.
Do not rev the engine above 3000 RPM under heavy load (full throttle).
and also not revving the engine too low, below 2000 RPM.
Regarding diesel, I would say use regular diesel (with a cetane number of 49 or higher) and don't add anything to it icon_wink.gif.
That's how I've broken in my diesel cars, and so far, those are two brand new cars.
And they all run perfectly and are incredibly quiet!
Please correct me if I've written something nonsensical here.
Translated on 01-11-2026, 7:45.
Mc_Givertechnik
2010 Volkswagen T5
Post28-04-2003, 19:06    Subject: 2-Stroke Oil: Break-in & Best Practices Quote
Two-stroke oil icon_question.gif icon_exclaim.gif icon_question.gif icon_exclaim.gif icon_biggrin.gif. I'm laughing my head off... I've never heard that before. I'm certainly no expert, but that tip is really cool. I assume that this measure is more likely to be detrimental to the cat (catalytic converter). Moreover, two-stroke oil also forms deposits on the valves, etc. However, with one liter per tank icon_confused.gif, nothing will happen. It certainly won't do anything good, it's more likely to cause harm. Please correct me if I'm wrong...
Go Trabbi, go...
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Translated on 01-11-2026, 7:47.
wuze60
Post28-04-2003, 19:10    Subject: 2-Stroke Oil: Break-in & Best Practices Quote
Sure!
Two-stroke oil is really bad for the catalytic converter. I almost forgot about that! I wouldn't have known if I hadn't read it now.
Back then, when I was a motorcycle mechanic, we took catalytic converters out of motorcycles every day because they got clogged with oil sludge. icon_evil.gif
Translated on 01-11-2026, 7:48.
Post28-04-2003, 19:11    Subject: 2-Stroke Oil: Break-in & Best Practices Quote
Hello neudiesel,
Okay, this is my fifth new TDI car, and I only put diesel in it. Otherwise, I agree with wuze60. Perhaps with the caveat that I'll keep the engine speed a little lower for the first 500 kilometers.
However, no matter how hard I try, I can't imagine what could be better lubricated in a PD engine by adding two-stroke oil. In fact, I could even imagine that it might be worse, not to mention what you'll end up emitting.
Matthias.
PS: I'm currently driving a PD with 130 horsepower... it's a good choice, even though you often hear negative things about it. However, I've only driven it for 18,000 km so far.
Translated on 01-11-2026, 7:49.
Mc_Givertechnik
2010 Volkswagen T5
Post28-04-2003, 19:52    Subject: 2-Stroke Oil: Break-in & Best Practices Quote
I've been thinking about this two-stroke oil again. If I remember correctly, every icon_exclaim.gif operating manual icon_exclaim.gif for TDI engines states that "NO" additives "of any kind" are allowed to be added icon_exclaim.gif icon_exclaim.gif icon_exclaim.gif icon_exclaim.gif.
Okay, if I had to run a "Lanz Bulldog" engine, we could talk about it, but with a highly modern engine like the PD, I think it would likely cause damage.
I definitely wouldn't do that.
Wishing you lots of fun with your new car!
Peter from Graz.
Translated on 01-11-2026, 7:51.
kenny
Post29-04-2003, 6:29    Subject: 2-Stroke Oil: Break-in & Best Practices Quote
Since when have there been two-stroke motorcycles (scooters?) with catalytic converters?
Translated on 01-11-2026, 7:52.
Uwe
Post29-04-2003, 17:01    Subject: 2-Stroke Oil: Break-in & Best Practices Quote
Hi!
Do NOT put two-stroke oil in the fuel tank. Among other things, it will change the viscosity of the diesel fuel, and this will increase the amount of diesel injected due to reduced leakage in the fuel injection pump, which is essentially a form of tuning.
Die PD-Elemente reagieren sicherlich nicht erfreut über so einen Saft. Sogar Biodiesel kann Schäden hervorrufen, was in den älteren Verteilereinspritzanlagen nicht so schlimm ist. AlKeep away!
I would recommend breaking it in by keeping the RPMs below 2,500 and using gentle acceleration. You'll see, with that kind of driving, you're not necessarily going to be slow...
Uwe.
Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
hansemann2,5
Post30-04-2003, 23:07    Subject: 2-Stroke Oil: Break-in & Best Practices Quote
I add 2T oil to my old BMW before I put it away for the winter. It's a fuel-injected engine, and after it's been driven and then turned off, the fuel evaporates, leaving behind a very thin film of oil that protects the fuel injectors, valves, and other components from corrosion.
I've heard that trick about using additives for diesel engines before, although it's usually with regular motor oil. I find your dismissive comments about how it's no longer necessary for our supposedly modern TDI engines to be exaggerated. You should just take a look at how many TDI engines are failing due to pump damage; that didn't happen as often in the past!
Well, a little lubrication can't hurt, right? After all, the fuel itself hasn't changed much, but the injection pressures have increased tenfold...
Translated on 01-11-2026, 7:54.
Post01-05-2003, 2:09    Subject: 2-Stroke Oil: Break-in & Best Practices Quote
"And that's exactly the problem; he wants to buy a TDI with PD technology. If he had one with VP technology, it might still be somewhat manageable. But I definitely wouldn't do it. I know that a liter of oil diluted in 55 liters of diesel is a very small amount, but that's also part of the problem. Why even bother? Besides the potential damage to things like the catalytic converter, the owner's manual explicitly states that only diesel fuel should be put in the tank."
Translated on 01-11-2026, 7:55.
diesel.gustav
Post01-05-2003, 14:51    Subject: 2-Stroke Oil: Break-in & Best Practices Quote
Deleted upon request.
Translated on 01-11-2026, 7:56.
No new posts Diesel Two-Stroke Oil: Protect Your Engine Diesel Engine Technology
No new posts Break-in period with/without tuning? Diesel Engine Technology
No new posts Breaking in a new turbo? Diesel Engine Technology
