kylie Guest
14-09-2009, 10:35 Subject: Skoda Felicia: Won't Start? Troubleshooting Guide |
Hello User!
The car was parked in the garage without any previous sputtering or other complaints, and then it suddenly wouldn't start. The workshop said that this was likely due to...
due to a faulty glow plug fuse, but that fuse is fine.
*correct fuel has been filled.
'Starter sounds good.'
*The engine immediately stalls when trying to start, without even sputtering or 'catching' once.
Does anyone have any other ideas about what we could try or check?
Thank you everyone, love Kylie  .
Translated on 01-10-2026, 22:58.
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
14-09-2009, 10:44 Subject: Skoda Felicia: Won't Start? Troubleshooting Guide |
Quote: | | The engine immediately stalls when attempting to start, without even once "catching" | .
What does that mean? Is the crankshaft actually turning?
Translated on 01-10-2026, 22:59.
Profile PM WWW Garage |
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
14-09-2009, 10:49 Subject: Skoda Felicia: Won't Start? Troubleshooting Guide |
Hello, do I understand correctly that the starter motor rotates until the piston passes the top dead center (TDC) position, and then the starter motor stops?
How long was the vehicle stationary after being parked?
Could the battery have collapsed?
Was ist die LL-Spannung/Anlaufspannung?
Disconnect the starter cable directly at the battery terminal and connect the ground cable to the starter motor. Measure the voltage during the starting process.
Or is the starter motor turning against the valves? Try turning it manually, or try pushing the car in 4th gear to see if it goes past Top Dead Center (TDC). Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 01-10-2026, 23:00.
Profile PM Email Garage |
luiggi Schrauber
Joined: 02/19/2006 Posts: 392 Karma: +4 / -0 Location: Tirol /Zillertal
14-09-2009, 18:33 Subject: Skoda Felicia: Won't Start? Troubleshooting Guide |
Could it not also be the case that something in the vehicle (e.g., the radio, interior lighting) was still running when the vehicle was parked? And then, the next day  ?
I would start by checking the battery. Maybe you can try swapping it with another vehicle. Then you'll see how it behaves when starting. Best regards.
Translated on 01-10-2026, 23:01.
kylie Guest
15-09-2009, 13:40 Subject: Skoda Felicia: Won't Start? Troubleshooting Guide |
No, no, the battery is fine, the starter is working as it should, but the engine...
It doesn't matter.
The amount of time the vehicle had been stationary since its last use was probably only about 10 hours.
I took it to the workshop yesterday, let's see what the problem was.
Best, Kylie
Translated on 01-10-2026, 23:02.
15-09-2009, 16:42 Subject: Skoda Felicia: Won't Start - 1.9 SDI Troubleshooting |
kylie wrote: | Hello User!*The engine stalls immediately when trying to start, without even "catching" once. Thank you to everyone, best regards, Kylie  |
What do you mean by that? Gruß, der Teileklaus
Translated on 01-10-2026, 23:03.
kylie Guest
16-09-2009, 10:40 Subject: Skoda Felicia: Won't Start? Troubleshooting Guide |
When I say 'it doesn't start,' I mean that when I try to start the engine and put it in first gear, the engine doesn't even turn over once; it immediately stalls. Perhaps it's also because the manual suggests trying to start the engine in second gear?
Conclusion: The workshop called today and said it was because all 4 glow plugs were faulty.
'were defective, and this old pre-combustion chamber engine requires one to be able to start.'
Best,
Kylie
Translated on 01-10-2026, 23:04.
matthiasTDI96 Profi-Schrauber
16-09-2009, 10:51 Subject: Skoda Felicia: Won't Start? Troubleshooting Guide |
Now I think we've reached the point where you owe us real information if you expect anything from us.
Naturally aspirated engine or direct-injection engine?
Stalling when starting up??? Is it mechanically blocked? First gear and walking pace? What is the starter motor doing?
I'm truly sorry, but even after reading a lot of text, I don't understand what you mean at all.
Translated on 01-10-2026, 23:05.
16-09-2009, 12:07 Subject: Skoda Felicia: Won't Start? Troubleshooting Guide |
S.C. direct injection?? Or what? Gruß, der Teileklaus
Translated on 01-10-2026, 23:06.
16-09-2009, 13:16 Subject: Skoda Felicia: Won't Start? Troubleshooting Guide |
Whatever a TDI without a turbo is, it's an SDI, so it has nothing to do with pre-combustion chambers.
The "I" definitely does not stand for "Indirect"!
kylie Guest
17-09-2009, 7:28 Subject: Skoda Felicia: Won't Start? Troubleshooting Guide |
* The SDI is running again.
* Grund lt. Werkstatt waren 4 defekte Glühkerzen (186€ incl. Arworking hours o.O)
(I'm glad it's done; it's a real pain to change these on a Felicia.)
(the thing about the pre-chamber, the workshop told me  lol).
* warum ich ihn nicht anrollen konnte ist mir rätselhaft (vlt. war der 1. (Tempo too low)
Thank you again to everyone for your commitment, but it's working again...
Best,
Kylie
Translated on 01-10-2026, 23:07.
