bindpe Blaumann
Joined: 08/25/2006 Posts: 203 Karma: +5 / -2 Location: ingolstadt
16-09-2009, 19:37 Subject: Timing belt replacement: What else should be replaced at the same time? |
Hello.
Thanks to numerous tips from this forum, I finally decided to buy a Gates timing belt for my G3 with an AHU engine. We're proactively replacing the water pump and tensioner along with the belt as well.
Okay, so the question is, what else should be replaced or serviced? I printed out the instructions from ELSA Win. For example, it doesn't mention anything about the KW screw; should that also be included in the replacement? If so, do you have a part number and torque specification for it? What other things should be done at the same time?
Thank you.
Golf III TDI AHU 402Tkm
Translated on 19-07-2026, 20:18.
lichti Blaumann
Joined: 09/07/2009 Posts: 46 Karma: +2 / -0 Location: PC-Österreich 2007 Volkswagen Golf Premium Support
24-09-2009, 9:58 Subject: Timing belt replacement: What else should be replaced at the same time? |
You don't actually need to replace the water pump, as it doesn't run synchronously with the timing belt! You can also change it separately if you want. But do whatever you feel is best!
Check the crankshaft and water pump seals for leaks; if there are any leaks, replace them!
"VDD is pretty obvious..."
Crankshaft bolt tightening torque: 90 Nm + 90°. Part number: N 905 771 01.
EX-Golf V GTI Edition30, Oettinger Abgasanlage - Chiptuning
EX-3BV Passat Variant Business Comfortline, AVB, Bj. 2003
6J1 Seat Ibiza Cupra, CAVE, Bj. 2010
Translated on 19-07-2026, 20:21.
Profile PM Garage |
24-09-2009, 11:21 Subject: Timing belt replacement: What else should be replaced at the same time? |
- There's still a small roller between the cam and the ESP unit - replace that one too.
- Do you have a camshaft sprocket holding tool? Use something sturdy; I almost couldn't get the screw off, and then it got stuck.
| Description: |
| File size: |
16.29 KB |
| Viewed: |
1812 times |
| Description: |
| File size: |
76.54 KB |
| Viewed: |
1288 times |
Translated on 19-07-2026, 20:23.
Profile PM Garage |
bindpe Blaumann
24-09-2009, 21:19 Subject: Timing belt replacement: What else should be replaced at the same time? |
Hello.
Thanks for the tips.
Do you also need to adjust the torque wrench setting if a screw with higher strength has already been installed?
Thank you.
Translated on 19-07-2026, 20:25.
24-09-2009, 21:38 Subject: Timing belt replacement: What else should be replaced at the same time? |
I didn't do it at 180,000 km... and the car now has its next service coming up  .
Translated on 19-07-2026, 20:27.
Profile PM Garage |
bindpe Blaumann
25-09-2009, 18:16 Subject: Please provide the German title you would like me to translate. |
Hello Dieselmartin.
I think I'm not going to replace them, provided that the correct ones with the high strength class are already installed.
Is it dependent on the year of construction?
Peter.
Translated on 19-07-2026, 20:28.
bindpe Blaumann
27-09-2009, 8:31 Subject: Please provide the German title you would like me to translate. |
Hello.
It's done! The ZR and wapu are new. I managed to loosen the central screw and replaced it.
I don't know how to remove the lower timing belt cover without loosening and removing the tensioner pulley, but it wasn't a problem.
Translated on 19-07-2026, 20:31.
