OT marking on a 3BG Passat 1.9TDI AVF with TT5 automatic transmission?
corryfan
Post24-09-2009, 21:25    Subject: OT marking on a 3BG Passat 1.9TDI AVF with TT5 automatic transmission? Quote
Can someone tell me where, regarding the above? Where can I find the 'OT' marking on the vehicle, specifically in the transmission area?
Does it actually work in the vending machine? I don't have a flywheel, just the starter ring gear.
Background:
'I recently replaced the timing chain and now I'd like to re-check and possibly fine-tune the timing, as it runs great at low RPMs like before, but it seems to struggle a bit at higher RPMs on the highway (referring to the early/late timing effect, as there are already a few threads on this topic).'
Since I don't want to disassemble half the front end again just to install the KW stop, I want to try marking the transmission first.
Okay, my charging voltage is a bit too high (the gauge reads slightly above the recommended range when the engine is cold, roughly in the middle of the metal tab at the end).
Does that make any sense?
Thank you in advance.
corryfan
Post28-09-2009, 17:54    Subject: OT marking on a 3BG Passat 1.9TDI AVF with TT5 automatic transmission? Quote
does icon_eek.gif anyone have a plan?
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts Automatic 01N with AFN Engine - Problem with the Gearbox ... General Tips
No new posts Doku Golf 5, Problems with windshield washer/water system Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts OT Markierung Kurbelwelle AFN Automatik Golf 3?? Diesel Engine Technology
No new posts Help: Shaking at 1.9TDI Passat, Year 1994 Diesel Engine Technology
No new posts Passat 2.5 TDI: 5-Speed Automatic Transmission Transmission, Chassis, Body & Interior
No new posts Automatic Transmission Repair: VW Passat 1.9 TDI Diesel Engine Technology
